[pgrouting-dev] Licensing for Co-development between OpenGraphRouter and pgRouting
Kishore Kumar justjkk at gmail.com
Fri Jun 3 00:46:28 EDT 2011
A quick question. I googled for PSC but couldn't find what it means. Is it a
formal club of people working on a project?
Thanks & Regards,
J Kishore kumar.
On Fri, Jun 3, 2011 at 9:18 AM, Stephen Woodbridge
<woodbri at swoodbridge.com>wrote:
> On 6/2/2011 11:18 PM, Daniel Kastl wrote:
>> 2011/6/3 Anton Patrushev <anton.patrushev at georepublic.de
>> <mailto:anton.patrushev at georepublic.de>>
>>     > There was some talk about merging with PostGIS. Is anything
>>    happening on that front or is that dead?
>>    Looks more like it's dead so far.
>> In my opinion it is not. Because it wasn't more than a first idea and
>> the earliest time would have been PostGIS 2.1 anyway. So I guess there
>> is still plenty of time and it's more up to pgRouting to do the
>> necessary work.
>> If integration into PostGIS is a goal, then changing or adding a license
>> isn't a topic, right?
> I think the bigger question is is the purpose of integrating with PostGIS?
> This is not to challenge whether not not we should do this, only to get a
> better understanding of the reasons and to validate them.
> Do we think it will get us more development? How and Why do we believe this
> would happen?
> Do we think it would improve the product from a technical, marketing,
> management, funding or other point of view? How and Why do we believe this
> would happen?
> Some other assumptions that we might have?
> So there is a good president for project consoldation, in that mod_geocache
> and tinyOWS are small projects that are in the process of moving their
> provenance and management under the mapserver PSC. Both of these projects
> provide functionality that are commonly needed by mapserver users and
> smoothing the integration and coordinating releases adds some value to the
> mapserver users and hopefully some of the mapserver developers will get
> involved with these projects.
> So back to your question of licensing ... As long as the license is not in
> conflict with the PostGIS licensing then it should not be a problem. For
> example today you use boost graph which has a permissive license like MIT-X
> and this is not a problem. If we moved all the core algorithm development
> into something like opengraphrouter and then wrote pgRouting wrappers to
> integrate it it would be the same as what you have now.
> But there would be a huge advantage to the permissive licensing if you
> remember a while back there was some discussion with Ingres database, or we
> might want to integrate into mysql, sqlite, spatialite or just write
> standalone routing daemons. Having license flexibility makes this much
> easier.
> Ok, so we don't want to hassle with re-licensing pgRouting, then if we can
> prove that opengraphrouter code can be integrated into pgrouting then we
> could look at what to would take to replicate the existing functionality in
> opengraphrouter and wrap that back into pgrouting and then continue core
> algorithm development there and use the pgrouting PSC as the governing body
> for this work.
> We have a way to go to prove this, but Ashraf is willing to work on this to
> prove that we can do it.
> -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110603/71c77638/attachment-0001.html
More information about the pgrouting-dev mailing list
