[pgrouting-dev] Ask about road table in routing.
Daniel Kastl daniel at georepublic.de
Fri Jun 3 04:26:31 EDT 2011
See here: http://www.pgrouting.org/docs/1.x/astar.html
2011/6/3 viet bui <buiviet9488 at gmail.com>
> Hi,
> I'm using pgrouting 8.3 version. and i found an website that show me how to
> routing using pgrouting and postgis.
> that a good information for me to do my work.
> but, when i follow the SQL file script, and insert data to Road table. I
> don't clearly know about each fields in Road table.
> can you show me the definition of each field and the meaning of it.
> for example :
> Fields  ---- meaning
> id  --  get the id of each point.
>  source -- .....smth.....
>  target -- ....
>  cost -- ....
>  reverse_cost --- .....
>  sens ----- .....
>  x1 ----- ......
>  y1------ .....
>  x2 ------......
>  y2 ------ ......
>  edge_id ----- .......
>  the_geom ------.....................
> thanks.
> *Mr. Vietbv*
> *Do your best , the rest will come**.*
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110603/5e01c958/attachment-0001.html
More information about the pgrouting-dev mailing list
