[pgrouting-dev] Time dependent data and input format
Jay Mahadeokar jai.mahadeokar at gmail.com
Sat Jun 11 12:58:06 EDT 2011
On Thu, Jun 9, 2011 at 9:16 AM, Jay Mahadeokar <jai.mahadeokar at gmail.com>wrote:
> Hi,
> Just a recap to our planned tdsp query model:
> I agree. So, now can we assume we have following database tables, as per
>> things discussed till now:
>>    1. Ways: (On lines of the one in pgrouting-workshop)
>>    - gid
>>    - source
>>    - target
>>    - name
>>    - the_geom
>>    - static_length    (In case time dependent routing is not used)
>>    - any other attributes..
>>     2.  TimeVaryingCosts (Any other suitable name?)
>>    - gid
>>    - start_time_and_date  (May divide this into two columns: day_of_week
>>    and time_of_day ? )
>>    - travel_time / arrival_time
>>     3. TurnRestrictions (Time dependent)
>>    - node/source
>>    - time_from
>>    - time_to
>>    - node_to
>>    - ancestors
>> If only static shortest path query is made, then only table 1 is required.
>> If time-dependent shortest path query is made, table 1 and 2 will be used.
>> If in time-dependent shortest path query with turn restrictions is made ,
>> all 3 tables will be used.
> So, for a general time dependent query, we will fetch edge information from
> ways table and the time dependent costs information from the
> TimeDepCosts table. (See previous msg above.)
> The query on ways table can be supplied by the usual as on normal dijkstra
> shortest_path() query.
> How do we form the query on the TimeDepCosts table? I see two options:
> 1. We generate the query according to the gids obtained from the query on
> ways table. We will have to query all the time slots available, or form a
> query so that the time-window is appropriate and we have sufficient
> travel_time info so that we can reach destination.
> Here we can form query like
> Select * from TimeDepCosts where gid in (list of gids queried from ways
> table).
> We can allow user to more filtering parameters according to start_time ,
> date ?
> But this will make our query specific to the database design. As already
> discussed, we cant predict the time units / requirements of applications and
> so it would be better if we keep the query independent of the database
> design.
> Thats the reason our weight_map assumes start time from source as 0, and
> all travel times offset from the start time from source. A function that
> will generate such weight map is to be written.
> 2. We allow user to pass the query for TimeDepCosts table too. So, we will
> have our pgsql function as:
> CREATE OR REPLACE FUNCTION shortest_path(
>                                                 ways_sql text,
>                                                 time_dep_cost_sql text,
>                                                 source_id integer,
>                                                 target_id integer,
>                                                 directed boolean,
>                                                 has_reverse_cost boolean)
>         RETURNS SETOF path_result
> This way, user can have more control on the amount of data being queried.
> We will only consider the time dependent windows that fit the query.
> Example of the time_dep_cost_sql can be:
> Select * from TimeDepCosts where " USER_SUPPLIED_CONSTRAINTS".
> The user can now supply his constraints according to time_window he needs,
> start times, holidays etc according to the database table design.
> The problem with this is, we cannot filter out edges according to bounding
> box etc since the_geom field is not there in this table. This is because
> that information would be redundant.
> Thoughts? Any idea that combines the merits of both approaches?
Hi all,
I am writing some background code will be needed for the above
functionality.
Any input on the above mentioned point? I suppose I should not start coding
for any specific approach until we agree upon a viable query strategy.
> Regards,
> -Jay Mahadeokar
Regards,
-Jay Mahadeokar
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110611/547f5a44/attachment.html
More information about the pgrouting-dev mailing list
