[pgrouting-dev] Support for Time Constraints
Jay Mahadeokar jai.mahadeokar at gmail.com
Sun Jun 12 04:33:22 EDT 2011
On Sun, Jun 12, 2011 at 1:32 PM, Anton Patrushev <
anton.patrushev at georepublic.de> wrote:
> Hi Jay,
> No, there was no specific meaning, just king of cyphering - first
> digit for road class and then two last digits for road type.
Hi Anton,
So, as you said last 2 digits are for road type. I can see they are mainly
00, 01, 02, 06, 08, 09, 10, 11, 12 ,14, 17.
Road class is just 1 or 4.
Can I differentiate major highways, minor highways, streets etc using this
info?
> Anton.
> On 6/12/11, Jay Mahadeokar <jai.mahadeokar at gmail.com> wrote:
> >> Hi Jay,
> >> I think that instead of just random times, I would take a different
> >> approach to generate this data. If we think about "rush hour" around a
> >> major
> >> city, the highways (based on road class) flowing into the city in the
> >> morning would get reduced average speeds you could apply curve like
> >> average
> >> speed*percent based on 6am (90%), 7am(75%), 8am(45%), 9am(50%),
> 10am(85%)
> >> and do something similar in the evening rush. It might be too hard to
> >> figure
> >> on direction of flow in/out bound so apply the curve to all traffic. The
> >> assumption is that the highways are congested which will force traffic
> >> onto
> >> side streets. You might want to also reduce the lower class speeds by
> say
> >> a
> >> constant 80% during rush hour.
> >> If we can get OSM data then it should be easy to populate the table with
> >> that data.
> >> -Steve
> > I am trying to write plpgsql query to generate time-dependent data
> > corresponding to the ways table in pgrouting workshop. As suggested by
> Steve
> > above, instead of generating random data, I will follow patterns (see
> above
> > message) so that the data is nearer to the real worlds scenario.
> > So, now I need to make distinction between highways, streets etc. I saw
> the
> > attribute class_id in ways table. It has 14 distinct values:
> >  class_id
> > 102
> > 122
> > 106
> > 111
> > 108
> > 100
> > 109
> > 112
> > 101
> > 110
> > 401
> > 119
> > 117
> >       114
> > Any specific meaning attached to these values? I did not find any
> > information on the pgRouting-workshop website [1].
> > Thanks in advance.
> > [1] http://workshop.pgrouting.org/chapters/topology.html
> > Regards,
> > -Jay Mahadeokar
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Anton Patrushev
> CTO
> eMail: anton.patrushev at georepublic.de
> Web: http://georepublic.de
> Tel: +49 (089) 420 959 519
> Sip: 1959519 at sipgate.de
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Regards,
-Jay Mahadeokar
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110612/9cc7eb1a/attachment.html
More information about the pgrouting-dev mailing list
