[pgrouting-dev] Support for Time Constraints
Stephen Woodbridge woodbri at swoodbridge.com
Sun Jun 12 16:39:01 EDT 2011
On 6/12/2011 2:59 PM, Jay Mahadeokar wrote:
> On Sun, Jun 12, 2011 at 8:00 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Jay,
>     Try:
>     select class_id, count(*) as cnt from ways group by class_id oder by
>     classid;
>     Typically you should a a distribution in real world data something like:
>     5% limited access major highways
>     15% major roads
>     75% minor roads
>     5% trails, pedestrian ways, etc
>     Well in the US anyway. Also if this is OSM data then you might get a
>     better clue on classes by looking to that .... OH!, look what I
>     found in google :)
>     http://workshop.pgrouting.org/chapters/advanced.html
> Hi Steve,
> Thanks for giving me the link. I somehow never tried doing advanced part
> of the workshop.
> Well, it is using routing database which we generate during this step:
> http://workshop.pgrouting.org/chapters/osm2pgrouting.html
> I am doing exact steps outlined there but unfortunately, after I run
> osmtopgrouting command,  get following output:
> <lots of mesages regarding different class name, and ids>
> class name = roundabout
> class id = 401
> class id = 401 name = roundabout added to type name=junction
> Trying to load data
> Trying to parse data
> I find only the following 3 tables generated in routing database:
>                 List of relations
>   Schema |       Name        | Type  |  Owner
>   public | geography_columns | view  | postgres
>   public | geometry_columns  | table | postgres
>   public | spatial_ref_sys   | table | postgres
> (3 rows)
> The tutorial says a total of 8 tables should be generated.
> I do not get any other warning or error messages.
> On other hand, I am able to do all steps here:
> http://workshop.pgrouting.org/chapters/topology.html correctly, and
> hence till now I was working with pgrouting-workshop database.
> I am sorry if this are very silly errors, but I have no previous
> experience working with such data. Any hint/link why I am not able to
> generate routing database?
Jay,
Sorry, I can not help as I have rarely used OSM data. I guess I need to
make time to work through those examples at some point.
Regardless, of the missing tables, if you have enough data to work with
and the doc link helps you understand it, then move forward if you can.
I will have to leave additional explaination up to others who will
hopefully  chime in.
-Steve
>     Looks like first digit is type and the three digits are from the
>     classes table.
>     -Steve
>     On 6/12/2011 4:33 AM, Jay Mahadeokar wrote:
>         On Sun, Jun 12, 2011 at 1:32 PM, Anton Patrushev
>         <anton.patrushev at georepublic.de
>         <mailto:anton.patrushev at georepublic.de>
>         <mailto:anton.patrushev at georepublic.de>>>
>         wrote:
>             Hi Jay,
>             No, there was no specific meaning, just king of cyphering -
>         first
>             digit for road class and then two last digits for road type.
>         Hi Anton,
>         So, as you said last 2 digits are for road type. I can see they are
>         mainly 00, 01, 02, 06, 08, 09, 10, 11, 12 ,14, 17.
>         Road class is just 1 or 4.
>         Can I differentiate major highways, minor highways, streets etc
>         using
>         this info?
>             Anton.
>             On 6/12/11, Jay Mahadeokar <jai.mahadeokar at gmail.com
>         <mailto:jai.mahadeokar at gmail.com>
>         <mailto:jai.mahadeokar at gmail.com>>> wrote:
>          >> Hi Jay,
>          >> I think that instead of just random times, I would take a
>         different
>          >> approach to generate this data. If we think about "rush hour"
>             around a
>          >> major
>          >> city, the highways (based on road class) flowing into the city
>             in the
>          >> morning would get reduced average speeds you could apply
>         curve like
>          >> average
>          >> speed*percent based on 6am (90%), 7am(75%), 8am(45%), 9am(50%),
>             10am(85%)
>          >> and do something similar in the evening rush. It might be too
>             hard to
>          >> figure
>          >> on direction of flow in/out bound so apply the curve to all
>             traffic. The
>          >> assumption is that the highways are congested which will force
>             traffic
>          >> onto
>          >> side streets. You might want to also reduce the lower class
>             speeds by say
>          >> a
>          >> constant 80% during rush hour.
>          >> If we can get OSM data then it should be easy to populate the
>             table with
>          >> that data.
>          >> -Steve
>          > I am trying to write plpgsql query to generate time-dependent
>         data
>          > corresponding to the ways table in pgrouting workshop. As
>             suggested by Steve
>          > above, instead of generating random data, I will follow patterns
>             (see above
>          > message) so that the data is nearer to the real worlds scenario.
>          > So, now I need to make distinction between highways, streets etc.
>             I saw the
>          > attribute class_id in ways table. It has 14 distinct values:
>          >  class_id
>          > 102
>          > 122
>          > 106
>          > 111
>          > 108
>          > 100
>          > 109
>          > 112
>          > 101
>          > 110
>          > 401
>          > 119
>          > 117
>          >       114
>          > Any specific meaning attached to these values? I did not find any
>          > information on the pgRouting-workshop website [1].
>          > Thanks in advance.
>          > [1] http://workshop.pgrouting.org/chapters/topology.html
>          > Regards,
>          > -Jay Mahadeokar
>             Georepublic UG (haftungsbeschränkt)
>             Salzmannstraße 44,
>             81739 München, Germany
>             Anton Patrushev
>             CTO
>             eMail: anton.patrushev at georepublic.de
>             Web: http://georepublic.de
>             Tel: +49 (089) 420 959 519
>             Sip: 1959519 at sipgate.de <mailto:1959519 at sipgate.de>
>         <mailto:1959519 at sipgate.de <mailto:1959519 at sipgate.de>>
>             Commercial register: Amtsgericht München, HRB 181428
>             CEO: Daniel Kastl
>             _______________________________________________
>             pgrouting-dev mailing list
>         pgrouting-dev at lists.osgeo.org
>         <mailto:pgrouting-dev at lists.osgeo.org>
>         <mailto:pgrouting-dev at lists.osgeo.org>>
>         http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>         Regards,
>         -Jay Mahadeokar
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
> Regards,
> -Jay Mahadeokar
More information about the pgrouting-dev mailing list
