[pgrouting-dev] Support for Time Constraints
Jay Mahadeokar jai.mahadeokar at gmail.com
Tue Jun 14 17:56:56 EDT 2011
On Mon, Jun 13, 2011 at 7:56 AM, Daniel Kastl <daniel at georepublic.de> wrote:
> Jay, there should be more tables.
> So something goes wrong with osm2pgrouitng. but from your output I can't
> guess what it is.
> Can you give some details (maybe in a new thread)
Hi Daniel,
Well, I must have been doing a silly mistake somewhere, it worked this time.
> Daniel
>> Well in the US anyway. Also if this is OSM data then you might get a
>>> better clue on classes by looking to that .... OH!, look what I found in
>>> google :)
>>> http://workshop.pgrouting.org/chapters/advanced.html
>> Hi Steve,
>> Thanks for giving me the link. I somehow never tried doing advanced part
>> of the workshop.
>> Well, it is using routing database which we generate during this step:
>> http://workshop.pgrouting.org/chapters/osm2pgrouting.html
>> I am doing exact steps outlined there but unfortunately, after I run
>> osmtopgrouting command,  get following output:
>> <lots of mesages regarding different class name, and ids>
>> class name = roundabout
>> class id = 401
>> class id = 401 name = roundabout added to type name=junction
>> Trying to load data
>> Trying to parse data
>> I find only the following 3 tables generated in routing database:
>>                List of relations
>>  Schema |       Name        | Type  |  Owner
>>  public | geography_columns | view  | postgres
>>  public | geometry_columns  | table | postgres
>>  public | spatial_ref_sys   | table | postgres
>> (3 rows)
>> The tutorial says a total of 8 tables should be generated.
>> I do not get any other warning or error messages.
>> On other hand, I am able to do all steps here:
>> http://workshop.pgrouting.org/chapters/topology.html correctly, and hence
>> till now I was working with pgrouting-workshop database.
>> I am sorry if this are very silly errors, but I have no previous
>> experience working with such data. Any hint/link why I am not able to
>> generate routing database?
>>> Looks like first digit is type and the three digits are from the classes
>>> table.
>>> -Steve
>>> On 6/12/2011 4:33 AM, Jay Mahadeokar wrote:
>>>> On Sun, Jun 12, 2011 at 1:32 PM, Anton Patrushev
>>>> <anton.patrushev at georepublic.de <mailto:anton.patrushev at georepublic.de
>>>> wrote:
>>>>    Hi Jay,
>>>>    No, there was no specific meaning, just king of cyphering - first
>>>>    digit for road class and then two last digits for road type.
>>>> Hi Anton,
>>>> So, as you said last 2 digits are for road type. I can see they are
>>>> mainly 00, 01, 02, 06, 08, 09, 10, 11, 12 ,14, 17.
>>>> Road class is just 1 or 4.
>>>> Can I differentiate major highways, minor highways, streets etc using
>>>> this info?
>>>>    Anton.
>>>>    On 6/12/11, Jay Mahadeokar <jai.mahadeokar at gmail.com
>>>>    <mailto:jai.mahadeokar at gmail.com>> wrote:
>>>>     >> Hi Jay,
>>>>     >> I think that instead of just random times, I would take a
>>>> different
>>>>     >> approach to generate this data. If we think about "rush hour"
>>>>    around a
>>>>     >> major
>>>>     >> city, the highways (based on road class) flowing into the city
>>>>    in the
>>>>     >> morning would get reduced average speeds you could apply curve
>>>> like
>>>>     >> average
>>>>     >> speed*percent based on 6am (90%), 7am(75%), 8am(45%), 9am(50%),
>>>>    10am(85%)
>>>>     >> and do something similar in the evening rush. It might be too
>>>>    hard to
>>>>     >> figure
>>>>     >> on direction of flow in/out bound so apply the curve to all
>>>>    traffic. The
>>>>     >> assumption is that the highways are congested which will force
>>>>    traffic
>>>>     >> onto
>>>>     >> side streets. You might want to also reduce the lower class
>>>>    speeds by say
>>>>     >> a
>>>>     >> constant 80% during rush hour.
>>>>     >> If we can get OSM data then it should be easy to populate the
>>>>    table with
>>>>     >> that data.
>>>>     >> -Steve
>>>>     > I am trying to write plpgsql query to generate time-dependent data
>>>>     > corresponding to the ways table in pgrouting workshop. As
>>>>    suggested by Steve
>>>>     > above, instead of generating random data, I will follow patterns
>>>>    (see above
>>>>     > message) so that the data is nearer to the real worlds scenario.
>>>>     > So, now I need to make distinction between highways, streets etc.
>>>>    I saw the
>>>>     > attribute class_id in ways table. It has 14 distinct values:
>>>>     >  class_id
>>>>     > 102
>>>>     > 122
>>>>     > 106
>>>>     > 111
>>>>     > 108
>>>>     > 100
>>>>     > 109
>>>>     > 112
>>>>     > 101
>>>>     > 110
>>>>     > 401
>>>>     > 119
>>>>     > 117
>>>>     >       114
>>>>     > Any specific meaning attached to these values? I did not find any
>>>>     > information on the pgRouting-workshop website [1].
>>>>     > Thanks in advance.
>>>>     > [1] http://workshop.pgrouting.org/chapters/topology.html
>>>>     > Regards,
>>>>     > -Jay Mahadeokar
>>>>    Georepublic UG (haftungsbeschränkt)
>>>>    Salzmannstraße 44,
>>>>    81739 München, Germany
>>>>    Anton Patrushev
>>>>    CTO
>>>>    eMail: anton.patrushev at georepublic.de
>>>>    <mailto:anton.patrushev at georepublic.de>
>>>>    Web: http://georepublic.de
>>>>    Tel: +49 (089) 420 959 519
>>>>    Sip: 1959519 at sipgate.de <mailto:1959519 at sipgate.de>
>>>>    Commercial register: Amtsgericht München, HRB 181428
>>>>    CEO: Daniel Kastl
>>>>    _______________________________________________
>>>>    pgrouting-dev mailing list
>>>>    pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>>>>    http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>>> Regards,
>>>> -Jay Mahadeokar
>> Regards,
>> -Jay Mahadeokar
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
Regards,
-Jay Mahadeokar
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110615/eec04662/attachment.html
More information about the pgrouting-dev mailing list
