[pgrouting-dev] Support for Time Constraints
Daniel Kastl daniel at georepublic.de
Wed Jun 22 12:19:13 EDT 2011
Hi Jay,
You could once import OSM data with http://osm2po.de/
You can't configure the import of attributes as you do with osm2pgrouting,
but the created tables have a good set of attributes.
So you don't need to worry much about what Steve mentioned, that there are
no clear rules for setting attributes.
Daniel
2011/6/23 Stephen Woodbridge <woodbri at swoodbridge.com>
> Hi Jay,
> For now just push forward with what you have for testing that should be
> fine.
> In general, the OSM data has lots of options for classification, but it
> does not have clear standards or descriptions on how segments SHOULD be
> classified, so it is easy for different people to interpret the
> classifications differently. Hence, you end up with a huge list of segment
> classes like on:
> http://workshop.pgrouting.org/**chapters/advanced.html<http://workshop.pgrouting.org/chapters/advanced.html>
> with only short 1-2 word descriptions. So for example what is the
> difference between motorway, motorway_link, motorway_junction or for that
> matter a lane, opposite, opposite_lane, track, byway, circleway,
> living_street, residential, road, secondary, tertiary, track, roundabout and
> grade* types and how should these be represented as classes or for average
> speeds?
> In the link above they are trying to deal with this same issue by assigning
> a cost to the classes table based on the type name. They then use that cost
> as a multiplier of the length which is weird, but kind of works. This
> assumes the a cost multiplier of 2.0 means that that class takes 2X as long
> to traverse that segment as a class with a cost multiplier of 1.0.
> UPDATE classes SET cost=2.0 WHERE name IN ('pedestrian','steps','**
> footway');
> versus:
> UPDATE classes SET cost=0.3 WHERE name IN ('motorway','motorway_**
> junction','motorway_link');
> and in these segments vehicle speed is faster to the cost is smaller.
> I take a more intuitive approach to this problem, by assigning an average
> speed for each class of segment, then length / average speed represents the
> average traversal time. So it is easy to make adjustments to the model and
> you can easily do shortest time or distance.
> -Steve
> On 6/22/2011 10:42 AM, Jay Mahadeokar wrote:
>> On Wed, Jun 22, 2011 at 7:57 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>>    Hi Jay,
>>    I am back from my trip and wading through emails.
>>    I am interested in what your rationale for looking a length as a
>>    classifier is. It would seem to me the length of a given segment has
>>    nothing to do with classifying a segment with respect to speed or
>>    road class. The length of a segment is typically a function of how
>>    often that route is intersected by other features. For example and a
>>    path through a city will have more intersections than a path through
>>    a rural country side. A mountain pass could be a very long segment
>>    but might be a very slow path because it is twisty and has a lot of
>>    elevation changes. A major road through a city might have
>>    intersections at every block hence have short segments but could
>>    still move a lot of traffic from one side of the city to another.
>>    For testing purposes, any random classification is fine, but I like
>>    to pick classifications the reasonably model real life so when I see
>>    the results they reflect some general cognitive expectations and I
>>    can understand then or detect anomalies which might indicat a bug in
>>    the algorithm.
>>    Maybe I am missing the point, anyway just trying to understand and
>>    not suggesting that you change anything at this point.
>> Hi Steve,
>> Well I was very confused regarding the classification too since I have
>> zero experience with real world data, and so I just choose length as
>> criteria. This data is just for test purpose. We can modify the model
>> and criteria any time, since writing the plsql procedure to generate
>> such does not take too much effort. Also, the data does not affect the
>> internal working of the algorithm, so I think for now, I can work with
>> the currently generated test data.
>> Any other ideas/ criteria for classification are welcome, and I would
>> write the scripts to generate corresponding data.
>>    -Steve
>>    On 6/17/2011 12:42 AM, Jay Mahadeokar wrote:
>>        Hi,
>>        Here is an interesting look into the data in ways table:
>>        pgrouting-workshop=# select round(avg(length)*10000) as avg,
>>        round(min(length)*10000) as min, round(max(length)*10000) as
>>        max,count(*) as count, class_id from ways group by class_id
>>        order by avg
>>        desc;
>>          avg  | min  |  max  | count | class_id
>>          5320 |  250 | 12163 |    21 |      101
>>          2135 | 1885 |  2385 |     2 |      111
>>          1970 |  396 |  5168 |    17 |      102
>>          1343 |   10 | 27485 |   234 |      106
>>          1115 |   33 |  7964 |   221 |      108
>>          1037 |   14 | 20020 |   248 |      109
>>           938 |    9 | 23142 |  2761 |      110
>>           837 |   21 |  2212 |    43 |      100
>>           626 |    8 |  3327 |    90 |      112
>>           619 |   26 |  9089 |   252 |      119
>>           486 |  123 |  1618 |    11 |      117
>>           473 |    7 | 16582 |  1259 |      114
>>           364 |   97 |  1578 |    45 |      122
>>           260 |    4 |   718 |   109 |      401
>>        (14 rows)
>>        So, I am going by the average length figure and considering
>>        class_id =
>>        (1001,111,102) as Type I (major_highways), which will be
>>        affected most
>>        by the traffic.
>>        class_id = (106,108,109,110,100) as Type II (minor_highways)
>>        which be
>>        comparatively less populated.
>>        class_id = (112,119,117,114,122,401) as Type III (streets) which
>>        will
>>        have least traffic.
>>        We want to have model such that during traffic hours the
>>        shortest path
>>        should go through streets.
>>        So, I am dividing day into following intervals, hope it sounds
>>        reasonable. I will write the corresponding plsql function that will
>>        generate the data accordingly. Note that the speed is in
>>        percentage of
>>        average speed. Since, we want to deal with time, we can effectively
>>        increase the lengths of the edges by same factor and assume speed
>> as
>>        constant.
>>        Time Interval   Speed for Type I        Speed for Type II
>>        Speed for Type III
>>        10 PM – 6 AM    100     100     100
>>        6 AM – 7 AM     95      90      100
>>        7 AM – 8 AM     80      75      90
>>        8 AM – 9 AM     50      45      85
>>        9 AM – 10 AM    60      55      85
>>        10 AM – 11 AM   90      85      95
>>        11 AM – 5 PM    100     100     100
>>        5 PM – 6 PM     90      85      95
>>        6 PM – 7 PM     75      70      90
>>        7 PM – 8 PM     50      45      85
>>        8 PM – 9 PM     60      55      85
>>        9 PM – 10 PM
>>                95      90      95
>>        Any feedback is welcome.
>>        I am currently stuck with a bug in the core time-dependent
>> function,
>>        there seems to be a problem with non-integer data. Will try and
>>        fix that
>>        soon.
>>        On Wed, Jun 15, 2011 at 7:26 AM, Jay Mahadeokar
>>        <jai.mahadeokar at gmail.com <mailto:jai.mahadeokar at gmail.**com<jai.mahadeokar at gmail.com>
>>         <mailto:jai.mahadeokar at gmail. com
>>        <mailto:jai.mahadeokar at gmail.**com <jai.mahadeokar at gmail.com>>>>
>> wrote:
>>            On Sun, Jun 12, 2011 at 8:00 PM, Stephen Woodbridge
>>        <mailto:woodbri at swoodbridge. com
>>        <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>> wrote:
>>                Jay,
>>                Try:
>>                select class_id, count(*) as cnt from ways group by
>> class_id
>>                oder by classid;
>>                Typically you should a a distribution in real world data
>>                something like:
>>                5% limited access major highways
>>                15% major roads
>>                75% minor roads
>>                5% trails, pedestrian ways, etc
>>            Hi,
>>            We have got following data in the pgrouting-workshop ways
>> table.
>>            pgrouting-workshop=# select distinct(count(class_id)) as
>>            no_of_entries,class_id from ways group by class_id order by
>>            no_of_entries;
>>              no_of_entries | class_id
>>                          2 |      111
>>                         11 |      117
>>                         17 |      102
>>                         21 |      101
>>                         43 |      100
>>                         45 |      122
>>                         90 |      112
>>                        109 |      401
>>                        221 |      108
>>                        234 |      106
>>                        248 |      109
>>                        252 |      119
>>                       1259 |      114
>>                       2761 |      110
>>            (14 rows)
>>            The classes table in routing database gives more information
>>        on the
>>            class_id field.  Also available here:
>>        http://workshop.pgrouting.org/ chapters/advanced.html
>>        <http://workshop.pgrouting.**org/chapters/advanced.html<http://workshop.pgrouting.org/chapters/advanced.html>
>>            So, we have:
>>            class_id    name                no_of_entries
>>            110           track               2761
>>            114           path                1259
>>            119           steps               252
>>            109           service            248
>>            106           primary            234
>>            108           living_street     221
>>            401           roundabout      109
>>            These are the major class_types with more than 100 entries
>>        in ways
>>            table.
>>            Steve had earlier suggested following idea for time
>>        dependent data
>>            generation:
>>        "If we think about "rush hour" around a major city, the highways
>>            (based on road class) flowing into the city in the morning
>>        would get
>>            reduced average speeds you could apply curve like average
>>            speed*percent based on 6am (90%), 7am(75%), 8am(45%), 9am(50%),
>>            10am(85%) and do something similar in the evening rush. It
>>        might be
>>            too hard to figure on direction of flow in/out bound so
>>        apply the
>>            curve to all traffic. The assumption is that the highways are
>>            congested which will force traffic onto side streets. You
>>        might want
>>            to also reduce the lower class speeds by say a constant 80%
>>        during
>>            rush hour."
>>            So, what classes should I consider as highways, what classes as
>>            streets and so on? Or What should be the pattern of speed
>>        changes in
>>            various classes?
>>            The main focus would be, we should be routed through less
>>        congested
>>            areas during rush hours right?
>>            Once we finalise this model, I can write the plsql function to
>>            generate the corresponding data.
>>                Well in the US anyway. Also if this is OSM data then you
>>        might
>>                get a better clue on classes by looking to that ....
>>        OH!, look
>>                what I found in google :)
>>                Looks like first digit is type and the three digits are
>>        from the
>>                classes table.
>>                -Steve
>>                On 6/12/2011 4:33 AM, Jay Mahadeokar wrote:
>>                    On Sun, Jun 12, 2011 at 1:32 PM, Anton Patrushev
>>        <anton.patrushev at georepublic. de
>>        <mailto:anton.patrushev@**georepublic.de<anton.patrushev at georepublic.de>
>>        <mailto:anton.patrushev@ georepublic.de
>>                    wrote:
>>                        Hi Jay,
>>                        No, there was no specific meaning, just king of
>>                    cyphering - first
>>                        digit for road class and then two last digits
>>        for road type.
>>                    Hi Anton,
>>                    So, as you said last 2 digits are for road type. I
>>        can see
>>                    they are
>>                    mainly 00, 01, 02, 06, 08, 09, 10, 11, 12 ,14, 17.
>>                    Road class is just 1 or 4.
>>                    Can I differentiate major highways, minor highways,
>>        streets
>>                    etc using
>>                    this info?
>>                        Anton.
>>                        On 6/12/11, Jay Mahadeokar
>>        <mailto:jai.mahadeokar at gmail. com <mailto:jai.mahadeokar at gmail.**
>>        <mailto:jai.mahadeokar at gmail.**com <jai.mahadeokar at gmail.com>>>>>
>> wrote:
>>         >> Hi Jay,
>>         >> I think that instead of just random times, I would take
>>                    a different
>>         >> approach to generate this data. If we think about "rush
>>                    hour"
>>                        around a
>>         >> major
>>         >> city, the highways (based on road class) flowing into
>>                    the city
>>                        in the
>>         >> morning would get reduced average speeds you could apply
>>                    curve like
>>         >> average
>>                    9am(50%),
>>                        10am(85%)
>>         >> and do something similar in the evening rush. It might
>>                    be too
>>                        hard to
>>         >> figure
>>         >> on direction of flow in/out bound so apply the curve to all
>>                        traffic. The
>>         >> assumption is that the highways are congested which will
>>                    force
>>                        traffic
>>         >> onto
>>         >> side streets. You might want to also reduce the lower class
>>                        speeds by say
>>         >> a
>>         >> constant 80% during rush hour.
>>         >> If we can get OSM data then it should be easy to
>>                    populate the
>>                        table with
>>         >> that data.
>>         >> -Steve
>>         > I am trying to write plpgsql query to generate
>>                    time-dependent data
>>         > corresponding to the ways table in pgrouting workshop. As
>>                        suggested by Steve
>>         > above, instead of generating random data, I will follow
>>                    patterns
>>                        (see above
>>         > message) so that the data is nearer to the real worlds
>>                    scenario.
>>         > So, now I need to make distinction between highways,
>>                    streets etc.
>>                        I saw the
>>         > attribute class_id in ways table. It has 14 distinct values:
>>         >  class_id
>>         > 102
>>         > 122
>>         > 106
>>         > 111
>>         > 108
>>         > 100
>>         > 109
>>         > 112
>>         > 101
>>         > 110
>>         > 401
>>         > 119
>>         > 117
>>         >       114
>>         > Any specific meaning attached to these values? I did not
>>                    find any
>>         > information on the pgRouting-workshop website [1].
>>         > Thanks in advance.
>>         > [1] http://workshop.pgrouting.org/ chapters/topology.html
>>        <http://workshop.pgrouting.**org/chapters/topology.html<http://workshop.pgrouting.org/chapters/topology.html>
>>         > Regards,
>>         > -Jay Mahadeokar
>>                        Georepublic UG (haftungsbeschränkt)
>>                        Salzmannstraße 44,
>>                        81739 München, Germany
>>                        Anton Patrushev
>>                        CTO
>>                        eMail: anton.patrushev at georepublic.de
>>                        Web: http://georepublic.de
>>                        Tel: +49 (089) 420 959 519
>>                        Sip: 1959519 at sipgate.de
>>        <mailto:1959519 at sipgate.de> <mailto:1959519 at sipgate.de
>>        <mailto:1959519 at sipgate.de>>
>>        <mailto:1959519 at sipgate.de <mailto:1959519 at sipgate.de>
>>        <mailto:1959519 at sipgate.de <mailto:1959519 at sipgate.de>>>
>>                        Commercial register: Amtsgericht München, HRB
>> 181428
>>                        CEO: Daniel Kastl
>>                        ______________________________ _________________
>>                        pgrouting-dev mailing list
>>        pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
>>        <mailto:pgrouting-dev at lists. osgeo.org
>>        <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>>        http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>>        <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>                    Regards,
>>                    -Jay Mahadeokar
>>            Regards,
>>            -Jay Mahadeokar
>>        Regards,
>>        -Jay Mahadeokar
>>    pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>> Regards,
>> -Jay Mahadeokar
>> ______________________________**_________________
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110623/ce2d999a/attachment-0001.html
More information about the pgrouting-dev mailing list
