R: Re: [pgrouting-dev] pgRouting render
Stephen Woodbridge woodbri at swoodbridge.com
Wed Jun 22 16:48:07 EDT 2011
Daniele,
as a follow on to my previous response, I would recommend starting with
the pgRouting tutorial if you haven't already worked through it:
http://www.google.com/#q=pgrouting+tutorial
http://www.google.com/#q=pgrouting+tutorial+foss4g
so you can understand some of the pieces and how they fit together, then
you need to decide how you can use these pieces in your desktop
application or if you need to replace one of them with something better
suited for your application.
-Steve
On 6/22/2011 4:32 PM, Stephen Woodbridge wrote:
> On 6/22/2011 12:58 PM, Daniele Russo wrote:
>> My application is a desktop application, and I work on Fedora 14. How
>> your web application works?
> So as a desktop application you have to decide if you want to build the
> UI based on a browser application using something like I did or if you
> want to code it in C/C++ or some other toolkit based language.
> I will describe my web application, but for another direction you need
> to ask how to do generic things for whatever toolkit you are using.
> Browser
> o OpenLayers
> o mapserver
> o render base map
> o render vectors from routing DB
> o ajax (PHP) to get route results
> o make route request
> o PHP gets request queries pgRouting
> o PHP formats results as XML back to OpenLayers
> o javaScript parse XML create route feature and populates directions
> pgRouting does not currently do the driving directions. This is custom
> code that I wrote for this application. I have explained how to do this
> on the list so check the archives. You can look at the demo web page to
> see how I glued OpenLayers and the Ajax requests together and in FireBug
> you can view the XML streams of the Ajax request.
> -Steve
>> Thanks, regards.
>> DR
>> Il giorno 22/giu/2011, alle ore 17.51, Stephen Woodbridge ha
>> scritto:
>>> On 6/21/2011 10:32 AM, danielerusso19 at libero.it wrote:
>>>> Thanks for the answer. Actually I'm using QuantumGIS, but I'd
>>>> like to use an engine like Navit.
>>> Probably need to ask this on the QuantumGIS and/or Navit list. In
>>> general, your question is given a polyline, how do I display that
>>> in XXXXX?
>>> pgRouting computes the route and gives you a polyline, the rest is
>>> up to you to feed it into rendering package. Your rendering package
>>> will depend on what you application development platform is, like
>>> Web 2.0 or desktop application, iPhone or Android application, etc.
>>> each of these will have different answers and constraints.
>>> You can look a web application that I built here:
>>> http://tinyurl.com/3rhn4nx
>>> This has a lot of custom code added to pgRouting but pgRouting is
>>> being used to compute underlying route.
>>> Hope this helps, -Steve
>>>> Is this possible?
>>>> Thanks, best regards.
>>>> DR
>>>> ----Messaggio originale---- Da: daniel at georepublic.de Data:
>>>> 21/06/2011 16.17 A:
>>>> "danielerusso19 at libero.it"<danielerusso19 at libero.it>, "pgRouting
>>>> developers mailing list"<pgrouting-dev at lists.osgeo.org> Ogg: Re:
>>>> 2011/6/21 danielerusso19 at libero.it<danielerusso19 at libero.it> Hi
>>>> all!
>>>> I would like to render my route (planned with pgRouting) in a
>>>> graphical way (2D or 3D, is the same). Is this possible? In which
>>>> way?
>>>> There are plenty ways to do so, but in the same manner as you
>>>> would render data in a PostgreSQL/PostGIS database, for
>>>> example:Mapserver/GeoservergvSIG, QGISOpenLayers (see the
>>>> workshop)Best regards,Daniel Thanks to all, regards.
>>>> DR _______________________________________________ pgrouting-dev
>>>> mailing list pgrouting-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> _______________________________________________ pgrouting-dev mailing
> pgrouting-dev mailing list
More information about the pgrouting-dev mailing list
