[pgrouting-dev] Support for Time Constraints
Stephen Woodbridge woodbri at swoodbridge.com
Thu Mar 31 10:19:41 EDT 2011
On 3/30/2011 9:45 PM, Daniel Kastl wrote:
>             float cost := getEdgeCost(time, vehicle_type, node_from,
>         node_to);
>             or something like that. Where time could be NULL for some
>         default
>             behavior, or a value that would be used to figure out the cost.
>             vehicle_type might be helpful if there are multiple costs to
>             traverse a link based on say, car, carpool, bus, truck, walking,
>             taxi, etc. This could also be used to implement the rules
>         for bus
>             and train lines.
> I think one of the difficulties with routing topic is that everyone
> (also myself) immediately think about routing in terms of vehicle types.
> It's the easiest example to explain pgRouting, but I think one premise
> of pgRouting is that it should work for any kind of network. Let's say
> your network would be the human nervous system. What is a vehicle there?
> Well, probably changing "vehicle_type" to "speed" would make sense, right?
Sorry for using vehicle as the selector maybe "service_type" would be
better, but the point is not the name, "speed" is equally misleading,
the point is to be able to be able to pass a selector to the under lying
function so that based on the selector we can compute an appropriate cost.
For my vehicle routing example, I chose: car, carpool, bus, truck,
walking, taxi, etc. because these might have different rules associated
to them. The selector values would be appropriate to the model that you
were working with.
car vs carpool vs bus - many cities have HOV lanes that bus and carpool
can use but not single occupancy cars. We might want to allocate a
higher speed to those lanes vs the normal lanes during rush hours.
Emergency vehicles many be allowed to make u-turns on highways that
other vehicles can not make. Trucks might be banned from some streets so
need to be costed appropriately, etc.
If we had a live traffic feed information linked to segment ids in
another table, The cost function could be implemented to check that
table and if a record exists then use that information or return the
standard information. By keeping this data in a separate table that is
presumably much smaller and dynamic than the street records it would
make it much easier and more cost effective to make dynmaic changes to
that table and to hide (abstract away complexity) by using a cost
function supplied to the underlying code.
-Steve
More information about the pgrouting-dev mailing list
