[pgrouting-dev] Re: Implementation of core Time Dependent Dijkstra function
Stephen Woodbridge woodbri at swoodbridge.com
Mon May 23 10:33:34 EDT 2011
I'm not a C++ programmer, but from what I have read on the boost list,
it seems that the path to writing generic templates is to write the code
first in regular C++ so it works and then refactor it to be more
generic. So step 1 is to do as you proposed.
Also since this project is to implement a "time dependent dijkstra
algorithm" in pgRouting, the generic templates seems to be out of scope.
It would be fine to do if you had the time and skill, but I think your
approach makes sense, use the tools that make your job easier and allow
you to achieve success.
Any contrary opinions to this?
-Steve
On 5/23/2011 10:20 AM, Jay Mahadeokar wrote:
> Hi,
> As initially discussed, I was trying to reuse the boost's dijkstra code
> to write the core time dependent dijkstra algorithm.
> Since Boost makes extensive use of generic programming, and I have no
> prior experience with such deep generic programming concepts, I was
> wondering if we really need all these features that boost provides.
> Another option would be to write the time-dependent dijkstra on our own.
> This will be a light-weight code without extensive use of generic
> programming like boost.
> So, i was thinking of using following:
> *1. *Boost::AdjecencyList - for storing graph.
> *2. *Std::Map - for storing distanceMap, predecessorMap.
> *3. *For weightMap:
> typedef struct weight_map_element
>          pair<int,double> edge;
>          double travel_time;
> weight_map_element_t;
> class weight_map
>      vector<weight_map_element_t> weight_map_set;
>      public:
>      void insert(weight_map_element_t element);
>      double get_travel_time(int edge_id, double start_time);
> *4. *std::priority_queue  for the priority queue that will be used for
> dijkstra search.
> Will this be sufficient for our implementation?  If yes, I will come up
> with the detailed internal function prototypes soon.
> On Wed, May 18, 2011 at 8:09 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     On 5/18/2011 8:08 AM, Jay Mahadeokar wrote:
>         Hi,
>         I think what we need is a function on following lines:
>         Given a query_start_time, it should query the TimeDepCosts
>         table, and
>         return the set of entries which have their start_time within
>         query_start_time + delta. This delta might be x hours, depending
>         on the
>         upper bound of the expected journey time.
>         We need following things handled in our model:
>         If query_start_time is 11PM Sunday and delta is 10 hours, we
>         will need
>         to query entries with start time between 11PM Sunday and 9AM
>         Monday. So,
>         basically the function needs to be periodic in terms of
>         time_of_day and
>         day_of_week.
>         As Steve suggested, we can maintain conventions for day_of_week
>         like:
>         -3   - holidays
>         -2   - weekend days
>         -1   - week days
>         0    - all days
>         1-7 Mon - Sun.
>         If we just assume entries for -3,-2,-1,0 and ignore each entry
>         for Sun -
>         Sat, that would reduce the space required assuming that the
>         entries for
>         weekdays is same. If times for different weekdays is different
>         then we
>         would have separate entries for each day.
>         So, the query should properly examine the query_day_of_week and
>         select
>         the proper entries. Ex: For above query, if it is sunday, then after
>         12AM, next entries will be queried with time_of_day as -1, but
>         if it was
>         Saturday, next entries will be queried with time_of_day as -2.
>         We can have a boolean parameter like *isHoliday* in query
>         itself, which
>         will tell if a given day (may be weekday) is holiday or not.Then
>         again
>         the query will have to be modified accordingly (query for -3).
>         This will
>         take care of query for local holiday etc and we do not have to worry
>         about calenders. The user will have to worry about that.. :-)
>     This (isHoliday) might work for a single day, but will not work if
>     the query crosses into the next day(s). Holidays are an input
>     convenience to describe recurring events. So say we have a
>     convenient way to input that data and store it into tables as we
>     have described, then the query for costs would need to decide is a
>     given day is a holiday or not and then select the correct entries to
>     return based on that. For ease of implementation, we could just
>     start with a stub function the returns false and later implement a
>     table lookup based on the date or day of year that determines if
>     isHoliday=t/f for any given start_time+offset.
>     Then when querying schedules, for example, we would select holiday
>     schedules if they exist and its a holiday otherwise search the
>     regular tables.
>         There can be time_from and time_to entries as well. But, if we
>         just have
>         entries like:
>           day_of_week: -1, time_of_day: 00:01, 55mph
>           day_of_week: -1, time_of_day: 07:00, 30mph
>           day_of_week: -1, time_of_day: 10:01, 55mph
>           day_of_week: -1, time_of_day: 16:31, 30mph
>         we can assume that the entry with time_of_day 00:01 is valid upto
>         07:00.  And if query_start_time is 02:00 and delta is 10 hours,
>         we can
>         query entries which have time_of_day < query_start_time + delta
>         (taking
>         care of change of day).
>         Is this assumption reasonable?
>     This sounds reasonable if the response is in units of time (offset)
>     from query_start_time. Assuming we use a resolution of seconds, then
>     the response would be in seconds from start time.
>         *weightMap Abstraction*
>         I think the design would be more modular if we keep the weightMap
>         independent of the underlying time conventions. Since as Daniel
>         pointed
>         out, this algorithm can also be used for non-road networks.
>         So, whatever the underlying time conventions, we can assume that
>         in the
>         end the query should return pairs like:
>         < <edgeId, offset_time> , travel_time/speed >
>         We will assume that query_start_time is 0, i.e we offset every
>         thing by
>         query_start_time.
>         The offset_time will be as follows:
>         As in above example,
>         If start_tme is 02:00 and day_of_week is -1, and delta as 10 hours.
>         Then, edge entries for edgeId 1 will be:
>         < <1, 05:00 > , 30 mph>
>         < <1, 08:01 > , 55 mph>
>         < <1, 14:31 > , 30 mph>
>         Basically, the offset_time will abstract out any internal details of
>         weekdays, change of days etc and it will just contain the offset
>         from
>         start_time.
>     I suggested seconds above, but if someone is modeling events in say
>     glacier flow, geological times or the big bang, they might need
>     other units of time. I would say that because we are talking about
>     time based schedules and need to deal with days, hours minutes we
>     should probably not worry about these other timeframes as the solver
>     will be offset based it will work with any units and then only the
>     wrappers for extracting the costs from the schedules would need to
>     change to deal with other timeframes. So lets not get hung up on
>     this, I think this is a sound plan.
>     -Steve
>         This will greatly simplify the core time dependent dijkstra
>         implementation.
>         Thoughts?
>         On Wed, May 18, 2011 at 10:46 AM, Stephen Woodbridge
>         <mailto:woodbri at swoodbridge.com>>> wrote:
>             Hi Daniel,
>             These are good points.
>             I agree that turn restrictions should be thought about but only
>             implemented if there is time. I think we should take the
>         discussion
>             of turn restriction into a separate thread. I'm interested
>         in what
>             you think is a limitation that can't be modeled in Dijkstra
>         or A*.
>             Regarding the time modeling, my point was just that we
>         needed more
>             thought there and a richer model developed. The crontab
>         model is a
>             good idea. I'm not opposed to modeling monthly or yearly
>         events, but
>             they rarely exist other than holidays which I tried to
>         capture. I
>             suppose you could model something like the Boston Marathon
>         and model
>             all the road closures and restrictions, but it seems to be a
>         lot of
>             work for a one day event, but I can see city government's
>         deploying
>             the resources to model something like this.
>             Regarding timezones: Times need to be entered with zones for
>         models
>             that cross zones but all the data should be converted to UTC
>             internally so it runs in a consistent time model. Timezones
>         are for
>             input and output, but the solver should be ignorant of them,
>         in my
>             opinion.
>             I have carried my GPS from the Eastern to central time zone,
>         and it
>             knew the local time when I powered it up. So my guess is that it
>             would auto correct when crossing the time zone.
>             -Steve
>             On 5/17/2011 10:42 PM, Daniel Kastl wrote:
>                 Hi Jay and Steve,
>                 This looks really nice, but let me give some comments
>         regarding
>                 how to
>                 model time, because this is really tricky in my opinion.
>                 Especially when
>                 thinking about an abstract network that isn't a road
>         network.
>                     Would it be possible to support turn restrictions in
>         the static
>                     Dijkstra also? I'm thinking just use all the same
>         structures but
>                     ignore the the time components to keep things
>         simple. So if
>                 the the
>                     turn restrictions table is present we use it, otherwise
>                 assume no
>                     restrictions. If doing static shortest path with turn
>                 restrictions
>                     then ignore the time components otherwise we use
>         them. And
>                 it is up
>                     to the user to make sure the turn restriction table
>         is valid
>                 for the
>                     analysis being requested.
>                 Currently in pgRouting Dijkstra and A* don't support turn
>                 restrictions
>                 modelling. What I actually like on Shooting Star is, that it
>                 routes from
>                 edge to edge instead of node to node. So it allows to model
>                 relations
>                 between edges rather than nodes, which I think is more
>         close to how
>                 humans would think of this.
>                 Dijkstra can only visit one node one times (as Shooting star
>                 only visits
>                 an edge once). Well, there can be turn restriction cases
>         where a
>                 node is
>                 passed twice and which can't be done correctly with
>         Dijkstra as
>                 far as I
>                 know.
>                 In the beginning I wouldn't think about the turn
>         restrictions
>                 too much.
>                 Let's take it as an extra when we see we still have
>         enough time.
>                 Of course if you have a good idea to implement it all at
>         once
>                 with only
>                 little extra work, then that's fine.
>                     For time definitions in your tables I think you need
>         to probably
>                     define some common structure for handling a time entry.
>                 Another problem might be time zones. Plain day field + time
>                 field might
>                 not be able to allow driving from one time zone to
>         another (or just
>                 think about a flight network). I never went from one
>         timezone to
>                 another
>                 by car or train, but Steve and Anton, you might have this
>                 experience.
>                 How does car navigation software handle this when you
>         cross the
>                 timezone
>                 border? ;-)
>                 So taking "timestamp with timezone" for those fields
>         might be a good
>                 idea to be able to support such a functionality.
>                     For example time_from and time_to might need to be
>         defined as a
>                     structure that includes day_of_week. day_of week
>         might take
>                 values like:
>                     -3   - holidays
>                     -2   - weekend days
>                     -1   - week days
>                     0    - all days
>                     1..7 - Sun,...,Sat
>                 I think the problem here is how to model recurring time
>                 dependent costs,
>                 right?
>                 If you think about weekdays, then you can't for example
>         model
>                 monthly or
>                 yearly events.
>                 I'm not really sure this is useful information here, but
>         I once saw
>                 about how the "iCal" format models recurring calendar
>         events:
>         http://ext.ensible.com/deploy/dev/examples/calendar/recurrence-widget.html
>                 Maybe we can learn something from there. The example
>         needed to be
>                 extended with some duration probably. But looking about
>         calendar
>                 formats
>                 might be a good idea to model holidays etc.
>                 Or another (stupid) example would be cron job syntax.
>         Something
>                 I always
>                 need to google for as I can't remember it ;-)
>                 All this time dependent stuff, events and schedules is
>         also an
>                 issue in
>                 Darp solver.
>                 And it probably is important also for the multi-modal
>         routing,
>                 so if we
>                 can find some clever way how to model this and can share
>         it between
>                 algorihtms, that would be great.
>                 Daniel
>                 Georepublic UG & Georepublic Japan
>                 eMail: daniel.kastl at georepublic.de
>         <mailto:daniel.kastl at georepublic.de>
>         <mailto:daniel.kastl at georepublic.de>>
>         <mailto:daniel.kastl at georepublic.de>>>
>                 Web: http://georepublic.de <http://georepublic.de/>
>                 _______________________________________________
>                 pgrouting-dev mailing list
>         pgrouting-dev at lists.osgeo.org
>         <mailto:pgrouting-dev at lists.osgeo.org>
>         <mailto:pgrouting-dev at lists.osgeo.org>>
>         http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>         Regards,
>         -Jay Mahadeokar
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
> Regards,
> -Jay Mahadeokar
More information about the pgrouting-dev mailing list
