[pgrouting-dev] Introducing myself
Razequl Islam ziboncsedu at gmail.com
Tue Apr 24 13:31:32 EDT 2012
Hi Steve,
It happens :-)
Thanks for the clarification. Actually I was a bit confused also. You may
call me Razequl or my nick name Zibon.
I think your test cases will be very helpful for testing the new
implementation.
Razequl
On Mon, Apr 23, 2012 at 10:16 AM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> Hi Razequl,
> I can be slow when I'm distracted by other things - I did not connect
> Razequl as being the same person as Khondoker that you proposal was
> submitted under until now when I was reviewing your proposal again. So
> please ignore my first bullet below and accept my apology.
> I have developed some test cases for the TRSP algorithm and we might be
> able to use them as tests for the bidirectional algorithm. I also have
> extensive datasets covering large areas that we can potentially use for
> performance testing.
> Thank you for your introduction.
> Best regards,
>  -Steve
> On 4/22/2012 2:01 PM, Stephen Woodbridge wrote:
>> Hi Razequl,
>> I have a few of comments in no particular order:
>> * We have a GSoC student that has proposed a project to do a
>> Bi-directional routing algorithm and we should know by tomorrow if that
>> was accepted or not. That said, while if it is accepted then having two
>> is a little redundant unless one supports turn restrictions like TRSP
>> and one does not.
>> * Boost as the advantage that is a generic library that is well tested
>> and most of the development is about how to use the library to do what
>> you want. On the other hand it is more restrictive if you want to do
>> something similar to Boost but not supported in the existing code. You
>> might be able to reuse some of the TRSP code which would be good if you
>> can do that.
>> * Testing - I think you need to consider making some simple unit test
>> examples that allow you to validate your code. This would be a
>> collection of tests that you can apply to a relatively simple network
>> that is easy to debug and trace the execution. Once this is done and
>> working it is reasonable to throw a larger network like osm2pgrouting to
>> look at performance tuning.
>> * One of the keys to making quality releases is our ability to automate
>> sanity testing of the code before we release it. While we do not have
>> any automated testing yet, it is very high on my list of things that
>> need to get done, so I will be pushing everyone to support this.
>> As Jay said, if you have any specific questions that we can help with,
>> please ask on the list.
>> Best regards,
>> -Steve
>> On 4/22/2012 1:00 PM, Razequl Islam wrote:
>>> Hi Jay,
>>> Thanks for your reply and suggestion. I have already gone through the
>>> source of basic dijkstra, A* and the new variant trsp (turn restricted
>>> shortest path) as suggested by Steve. I found that dijkstra and A* has
>>> been implemented using the boost library while trsp has its own
>>> structure and implementation. It also uses STL for priority queue. I am
>>> thinking of implementing like trsp using my own data structure.
>>> I am still playing with these. I need some sample database, I am trying
>>> to install osm2pgrouting but struggling.
>>> Thanks for your help once again.
>>> Razequl
>>> On Sat, Apr 21, 2012 at 12:34 AM, Jay Mahadeokar
>>> <jai.mahadeokar at gmail.com <mailto:jai.mahadeokar at gmail.**com<jai.mahadeokar at gmail.com>>>
>>> wrote:
>>> Hi Razequl,
>>> Welcome to pgRouting. Good implementation of Bi-directional
>>> searching algorithm will be a very useful addition to pgRouting. I
>>> would suggest you to:
>>> - See the pgRouting source.
>>> - Study typical pgRouting algorithm implementation link
>>> shortest_path, play around with it, compile and debug etc. You will
>>> need to use cmake and other tools for the same.
>>> - Think about design the data structures and modules that will be
>>> needed for Bi-directional algorithm implementation and discuss the
>>> same in the list.
>>> Steve and Daniel will surely provide useful insights and guidance
>>> for you. :-)
>>> Let us know if you have any queries.
>>> Regards,
>>> On Fri, Apr 20, 2012 at 10:12 PM, Razequl Islam
>>> <ziboncsedu at gmail.com <mailto:ziboncsedu at gmail.com>> wrote:
>>> Hi,
>>> I am Razequl Islam, student of Dhaka university, Bangladesh. I
>>> am new to the group. I am interested in implementing bi
>>> directional searching algorithms in pgrouting, Your feedback and
>>> suggestions are welcome.
>>> Best Regards,
>>> Razequl
>>> ______________________________**_________________
>>> pgrouting-dev mailing list
>>> pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>> -Jay Mahadeokar
>>> Mtech, II Year,
>>> IIT Kanpur,
>>> India.
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120424/8be66d1d/attachment.html
More information about the pgrouting-dev mailing list
