[pgrouting-dev] Question about improving alpha shapes
Mario Basa mario.basa at gmail.com
Wed Aug 22 17:54:16 PDT 2012
I forgot to add, st_concavehull also does holes quite nicely.
see attached screen dump.
Mario.
On Thu, Aug 23, 2012 at 4:32 AM, Steve Horn <steve at stevehorn.cc> wrote:
> For what it's worth:
> Wouldn't get too excited about the PostGIS 2.0 implementation of
> st_concavehull. It does allow for more flexibility but I found it to be a
> couple orders of magnitude slower than the pgRouting (CGAL) implementation.
> On Wed, Aug 22, 2012 at 4:03 PM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> Hello T,
>> Lots of good questions.
>> In general, as you found out, "One size fits all" solutions tend to not
>> work well for everyone. So I think have multiple solvers for various
>> problems is a good idea. In an ideal world, we would build things such that
>> they can be chained together, such that the output of one part can be fed
>> as input into the next part.
>> So if we had something like:
>> solve graph -> points with costs -> makealpha -> geometries
>> Where makealpha could be any number of solutions like convex hulls,
>> concave hulls, your_code, etc
>> In fact I have code the takes points with costs and makes a triangulated
>> surface and then slices that at z-levels and extracts geometries from that,
>> but not integrated into pgRouting at the moment.
>> So, yes, contributions are welcome. Don't think of them as needing to be
>> exclusive of other existing solutions.
>> Thanks,
>>   -Steve
>> On 8/22/2012 3:29 PM, T S wrote:
>>> Hello,
>>> For some projects I've been working on, I've had to make some
>>> modifications to the alphashape method -
>>> namely, allowing a custom alpha instead of just picking the optimal
>>> regularly connected alpha, and allowing for disconnected multipolygons
>>> instead of only returning a single polygon.
>>> The use case that comes up is that some networks have holes or gaps in
>>> the 2d plane. I.e., driving over a bridge, you can get to the
>>> landmasses on either side of the bridge, but you can't really get to
>>> all the water around the bridge. This water shouldn't be included in
>>> the polygon.
>>> I have an initial implementation of how this works, I have a few
>>> questions about trying to contribute it in -
>>> 1.) Is there any interest in this feature? Or does pgRouting prefer
>>> the current behavior?
>>> 2.) I noticed an earlier email thread discussing moving to
>>> st_concavehull in postgis 2.0. While this would remove the dependency
>>> on CGAL, st_concavehull doesn't appear to support returning multiple
>>> disconnected geometries, and it's not really a true alpha shape.
>>> 3.) If there is interest in moving this in, where should I look to for
>>> coding standards, and which parts of the API are 'stable' and which
>>> aren't? in specific -
>>> 4) why does points_as_polygon return a setof geoms instead of just a
>>> geometry?
>>> 5) is it important for there to be both a points_as_polygon() and an
>>> alphashape() function, or could the functionality be rolled up?
>>> Thank you,
>>> T
>> ______________________________**_________________
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
> Steve Horn
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120823/06e05010/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120823/06e05010/attachment-0001.png>
More information about the pgrouting-dev mailing list
