[pgrouting-dev] Library using plpython
Stephen Woodbridge woodbri at swoodbridge.com
Sat Feb 11 11:15:16 EST 2012
On 2/11/2012 10:44 AM, Steve Horn wrote:
> Was wondering if there has been any thought to creating a branch of
> pgrouting that implements the routing algorithms using python or another
> higher level programming language?
> Are there reasons for needing to stick with a C/C++ implementation?
Hi Steve,
This is a good question.
 From a pgRouting perspective, unless you want to implement the
algorithm in pl* languages, you really have to use C/C++ to implement
server extensions. And given the potential amount of data that needs to
be accessed and temporary data managed, this is the option for performance.
 From a pure can it be implemented in Python, there are no constraints.
   https://www.google.com/#q=dijkstra+python
shows some possible implementations.
-Steve W
More information about the pgrouting-dev mailing list
