[pgrouting-dev] BDSP Crashes
Stephen Woodbridge woodbri at swoodbridge.com
Fri Jul 6 10:40:41 PDT 2012
Hi Razequl,
Thank you for taking a look. For now you should drop this issue, and get
back to working on your plan. I will try to do some more testing on my
server and see if I can figure out what is happening here.
My server is running an outdated Debian lenny that I have not had time
to update. It has 4GB memory 64 bit OS and is generally very stable, but
as I said it is out dated so that might be the problem.
If you check in your test program and my csv file, I can try running
that here and see what I get.
-Steve
On 7/6/2012 1:33 PM, Razequl Islam wrote:
> Hi Steve,
> I could not reproduce the crashing bug in my pc. I have created the st
> table from data as you instructed. Here is the summary:
> routing=# \d st;
>                                 Table "public.st <http://public.st>"
>    Column  |       Type       |                    Modifiers
>   gid      | integer          | not null default
> nextval('st_gid_seq'::regclass)
>   id       | double precision |
>   source   | double precision |
>   target   | double precision |
>   cost     | numeric          |
>   rev_cost | numeric          |
>   the_geom | geometry         |
> Indexes:
>      "st_pkey" PRIMARY KEY, btree (gid)
>      "st_the_geom_gist" gist (the_geom)
> Check constraints:
>      "enforce_dims_the_geom" CHECK (st_ndims(the_geom) = 2)
>      "enforce_geotype_the_geom" CHECK (geometrytype(the_geom) =
> 'MULTILINESTRING'::text OR the_geom IS NULL)
>      "enforce_srid_the_geom" CHECK (st_srid(the_geom) = 4326)
> The table has 41580 rows. Then first I run the the following query and
> got the mentioned output
> routing=# select * from bidir_dijkstra_shortest_path('select gid as id,
> source::integer, target::integer, cost::double precision as cost,
> rev_cost:: double precision as reverse_cost from st', 1187405, 1187508,
> true, true);
>   vertex_id | edge_id |       cost
>     1187405 |   28874 | 11.3385436250298
>     1187406 |   28819 |  16.928515840577
>     1187508 |      -1 |                0
> (3 rows)
> After that I ran your query, just changing some of the variables, like
> gid in place of link_idand cost and rev_cost respectively in place of
> cost_time and rcost_time respectively. This query also returned the
> mentioned result without any problem.
> routing=# select * from st, (select gid, the_geom from
> bidir_dijkstra_shortest_path('select gid as id, source::integer,
> target::integer, cost::double precision as cost, rev_cost:: double
> precision as reverse_cost from st a', 1187405, 1187508, true, true), st
> where edge_id = gid) as rt where st.gid = rt.gid;
>    gid  |    id    | source  | target  |       cost       |
> rev_cost     |
> the_geom                                                   |  gid
> |                                                   the_geom
>   28819 | 25345248 | 1187508 | 1187406 |  16.928515840577 |
> 16.928515840577 |
> 0105000020E610000001000000010200000002000000B806B64AB038B4BFEF38454772C9494059A31EA2D11DB4BFBD5296218EC94940
> | 28819 |
>   28874 | 25345111 | 1187405 | 1187406 | 11.3385436250298 |
> 11.3385436250298 |
> 0105000020E610000001000000010200000002000000F623456458C5B3BF44696FF085C9494059A31EA2D11DB4BFBD5296218EC94940
> | 28874 |
> (2 rows)
> I have run several other queries with success.
> I am not sure what is causing your server crash. It will be very helpul
> if you provide some more information on the server like memory etc. I am
> running ubuntu 12.04 on a core i5 processor with 4GB memory. Another
> thing may be helpful, running shortest_path instead of
> bidir_dijkstra_shortest_path first. If it runs correct, then we are sure
> that every other things are right with the query. Then just change the
> shortest_path to bidir_dijkstra_shortest_path.
> I am still trying to break it. Please let me know if there are other
> ways to do it.
> -Razequl
> On Mon, Jul 2, 2012 at 6:51 PM, Razequl Islam <ziboncsedu at gmail.com
> <mailto:ziboncsedu at gmail.com>> wrote:
>     Hi Steve,
>     I downloaded the csv file and used my test application. But it ran
>     fine and produced the following output:
>     1187405 | 25345111 | 11.338544
>     1187406 | 25345248 | 16.928516
>     1187508 | -1  | 0.000000
>     I ran some other queries on the graph but could not crash the
>     program. So I suspect the problem may lie in the wrapper classes. I
>     will create a table and run the query.
>     -Razequl
>     On Mon, Jul 2, 2012 at 10:25 AM, Stephen Woodbridge
>     <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>         Argh! sorry my bad. Try:
>         http://imaptools.com:8080/dl/ test.tgz
>         <http://imaptools.com:8080/dl/test.tgz>
>         -Steve
>         On 7/1/2012 11:45 PM, Razequl Islam wrote:
>             Hi Steve,
>             I am trying to download the csv but ending up with 404 Not
>             Found error.
>             Please confirm the URL works. I am also getting the same
>             problem with
>             http://imaptools.com/dl/test. tgz
>             <http://imaptools.com/dl/test.tgz>
>             -Razequl
>             On Sun, Jul 1, 2012 at 7:37 PM, Stephen Woodbridge
>             <mailto:woodbri at swoodbridge. com
>             <mailto:woodbri at swoodbridge.com>>> wrote:
>                  Razqequl,
>                  I have not looked into the reason, but my intuition it
>             that it may
>                  be because this graph has about 50K edges so it will be
>             larger than
>                  most anything that you generated by hand, and the edge
>             and node
>                  numbers are very large because this is an extract from
>             a 10s of
>                  million of edges graph. There were no error message
>             other than the
>                  generic postgresql message the the server crashed. You
>             will probably
>                  fine you have a segv in your test program.
>                  I can download a zipped copy of the csv file. The first
>             row is the
>                  column names.
>             http://imaptools.com/dl/bdsp- big-bug.zip
>                  <http://imaptools.com/dl/bdsp- big-bug.zip
>             <http://imaptools.com/dl/bdsp-big-bug.zip>>
>                  -Steve
>                  On 7/1/2012 5:18 AM, Razequl Islam wrote:
>                      Hi Steve,
>                      Bad news :(
>                      As I mentioned, I already have a test application
>             to read from text
>                      file, it will be very helpful if you send me a csv file
>                      containing the
>                      graph. Also please let me know if there is any
>             error message. I am
>                      looking into my code for a possible reason.
>                      -Razequl
>                      On Sun, Jul 1, 2012 at 3:19 AM, Stephen Woodbridge
>             <mailto:woodbri at swoodbridge>. com
>             <mailto:woodbri at swoodbridge.com>>>> wrote:
>                           Hi Razequl,
>                           I tried a larger test and it crashed the server.
>                           You can test it like this:
>                           # fetch a test file from my server
>                           wget http://imaptools.com/dl/test. tgz
>                           <http://imaptools.com/dl/test. tgz
>             <http://imaptools.com/dl/test.tgz>>>
>                           # extract the tarfile into directory test
>                           tar xzf test.tgz
>                           # load the file into your test database into
>             table "st"
>                           shp2pgsql -s 4326 -c -D -I -N skip
>             test/bdsp-bug.shp st |
>                      psql -U
>                           user -h localhost mydatabase
>                           # get into psql or pgadmin and run the following
>                           psql -U user -h localhost mydatabase
>                           SELECT * FROM st, (
>                                          SELECT gid,the_geom
>                                            FROM
>                                              'SELECT link_id  as id,
>                                                       source::integer,
>                                                       target::integer,
>                                                       cost_time::double
>             precision as
>                      cost ,
>                                                       rcost_time as
>             reverse_cost
>                                                 FROM st a',
>                                              1187405,
>                                              1187508,
>                                              true,
>                                              true
>                                     ), st where edge_id = link_id
>                                ) as rt
>                                WHERE st.gid=rt.gid;
>                           This crashes my server!
>                           If you want to write a testmain.cpp, I can
>             provide the
>                      graph data in
>                           a csv file that you could read in and pass to
>             your code
>                      instead of
>                           the query to get the data from table st.
>                           -Steve
>                           ______________________________ _________________
>                           pgrouting-dev mailing list
>             pgrouting-dev at lists.osgeo.org
>             <mailto:pgrouting-dev at lists.osgeo.org>
>                      <mailto:pgrouting-dev at lists. osgeo.org
>             <mailto:pgrouting-dev at lists.osgeo.org>>
>             <mailto:pgrouting-dev at lists>. osgeo.org <http://osgeo.org>
>             <mailto:pgrouting-dev at lists.osgeo.org>>>
>             http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>                           <http://lists.osgeo.org/
>             <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev> > >
>                  <http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
More information about the pgrouting-dev mailing list
