[pgrouting-dev] Boston Code Sprint
Sanak geosanak at gmail.com
Sun Jul 15 06:07:22 PDT 2012
Hi Stephen, Daniel, Mario and Regina,
I think that Regina's proposal is good news for pgRouting Windows users
like me.
(Windows users will be able to install pgRouting from Application Stack
Builder GUI.)
I will be a little bit busy from next week to middle of November for mobile
development learning,
but if the issues (especially Windows packaging and old one) exists, I will
contribute as far as I can.
Regards,
2012/7/15 Stephen Woodbridge <woodbri at swoodbridge.com>
> Hi Daniel and Mario,
> There is going to be a Boston code sprint in February or March 2013 that I
> am planning on attending. (see email below). I would like to work on
> pgRouting and want to open up the discussions about integrating it with
> postGIS again, at least from a build and release point of view if not in
> other ways that might be acceptable to all.
> I know Mario is working on stuff now. It would be good to try and coral
> the various random work being done into some kind of mini freeze before
> this event which is TDB.
> To this end, I would like to get a list of what Mario is working on and
> any timeline if he has one. Additional input from Sanak, Steve Horn, Max
> Weninger, and Jay Mahadeokar, Razequl, Jinfu and anyone else that might
> have a fork and changes that might need to get integrated. If you have
> generated any RFC's or have ticket numbers that would be handy if you
> supplied links to them.
> I would like to also get a list of priority items that I should try to
> focus on for the sprint. High on my list of issues is putting in place an
> automated test framework that can be run via "make test" so that developers
> can check that changes do not break things. And to establish a pattern for
> future additions. My thoughts on this are that we need two levels of
> testing:
> 1. high level via sql commands
> 2. low level command line tool the reads a text file, sets up structs and
> then calls the algorithm code all outside of postgresql.
> This allows for simple low-level algorithm verification and debugging via
> gdb. While the higher level test can be used to validate wrapper and
> database integration separate from the algorithm. Both of these can use the
> same test data using a simple tool to extract the sql tables into a text
> file for the low-level tests. TRSP already has a commandline tool like
> this. and I believe Razequl and Jinfu have developed a tool like this for
> there own test efforts.
> Code sprinters, I would value you input as well if you have input on any
> of these issues.
> Thanks to all,
>   -Steve
> On 7/14/2012 2:13 PM, Paragon Corporation wrote:
>> Steven,
>> It would be great to have you.  I've cc'd Mark, Mat, Paul, Olivier, and
>> strk
>> since you mentioned pgRouting.  I know Olivier is interesting in pgRouting
>> as well.
>> One of the issues I see is that pgRouting has a CMake build structure.
>>  Mat
>> and Mark have been working hard to change PostGIS to have a CMake build
>> system as well.  I think this will make pgRouting easier to integrate with
>> PostGIS.
>> One of our hopes is that once CMake build is in full swing we can start
>> packaging pgRouting for windows alongside our PostGIS windows builds.
>>  This
>> is one issue some windows folks have raised about not wanting to use the
>> newer PostGIS/PostgreSQL versions because they rely on pgRouting and
>> binaries (at least for windows) are hard to come by.
>> We're also thinking about having a similar campaign for packaging
>> pgRouting
>> (at least for windows) that we did for the window 64-bit.  We've been
>> hesitant just because we haven't surmised the effort involved to do so.
>> This could help with the cost of migrating to a CMake build system and
>> testing the CMake build system.
>> Thanks,
>> Regina
>>  -----Original Message-----
>>> From: Stephen Woodbridge [mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>
>>> Sent: Friday, July 13, 2012 8:41 PM
>>> To: Paragon Corporation
>>> Subject: Re: Boston Code Sprint
>>> On 7/10/2012 8:25 PM, Paragon Corporation wrote:
>>>> Steve,
>>>> You're near Boston right and are heavily involved in MapServer,
>>>> PostGIS, etc?  You think you could partake in the Boston
>>> Code sprint
>>>> coming up that we are hosting?
>>>> Would be nice to chat about geocoding and other things.
>>>> http://wiki.osgeo.org/wiki/**Boston_Code_Sprint_2013<http://wiki.osgeo.org/wiki/Boston_Code_Sprint_2013>
>>>> Thanks,
>>>> Regina and Leo
>>> I would like to come and meet people.
>>> I might be able to do some hacking also. :)
>>> I would like to talk about pgRouting also. I know there have
>>> been some discussions in the past about combining this with
>>> postGIS but I was not part of that.
>>> Thanks,
>>>     -Steve
> ______________________________**_________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120715/5f46cb7c/attachment.html>
More information about the pgrouting-dev mailing list
