[pgrouting-dev] postgis2 and driving distance
Stephen Woodbridge woodbri at swoodbridge.com
Wed Jun 20 08:15:37 PDT 2012
You should be able write a simple wrapper for st_startpoint like:
create or replace function pgr_startpoint(line geometry)
returns geometry as
$body$
declare
   pnt geometry;
begin
   if geometrytype(line) = 'LINESTRING' then
     pnt := st_startpoint(line);
   elsif geometrytype(line) = 'MULTILINESTRING' then
     pnt := st_startpoint(st_geometryn(line,1));
   else
     return null;
   end if;
   return pnt;
end;
$body$
   language plpgsql stable;
I think we need to support MULTILINESTRING because the shapefile loader
creates then by default. I understand that "real" MULTILINESTRING
objects may not make sense but we can also just state the ALL
MULTILINESTRING objects will be treated as those it is a valid
contiguous path from start point to end point and that it is the users
responsibility for model the graph correctly if they have a different
interpertation of what a MULTILINESTRING means in their models.
-Steve
On 6/20/2012 2:37 AM, Daniel Kastl wrote:
> Hi Mario,
> Thank you for this information!
> Which files exactly do you mean with "wrapper sql files"?
> So this means the line geometry MUST be LINESTRING from now? Or is there
> an alternative function to ST_startpoint?
> Maybe it's better that import tools like osm2po create a correct
> geometry type as MULTILINESTRING doesn't make sense really for a routing
> network anyway.
>   In the past it just didn't matter if you had LINESTRING or
> MULTILINESTRING, right?
> I will create a ticket for this.
> Daniel
> On Wed, Jun 20, 2012 at 5:40 AM, Mario Basa <mario.basa at gmail.com
> <mailto:mario.basa at gmail.com>> wrote:
>     Daniel,
>     You might want to limit st_startpoint usage in your devel-2.0
>     wrapper sql files. According to documentation:
>     Changed: 2.0.0 no longer works with single geometry
>     multilinestrings. In older versions of PostGIS -- a single line
>     multilinestring would work happily with this function and return the
>     start point. In 2.0.0 it just returns NULL like any other
>     multilinestring. The older behavior was an undocumented feature, but
>     people who assumed they had their data stored as LINESTRING may
>     experience these returning NULL in 2.0 now.
>     I used osm2po to create the Japan networks and am getting nulls when
>     I use st_startpoint.
>     Mario.
>     On Tue, Jun 19, 2012 at 6:10 PM, Daniel Kastl <daniel at georepublic.de
>     <mailto:daniel at georepublic.de>> wrote:
>         Hi Mario,
>         I think it's a good idea to drop CGAL if possible ... and you
>         proofed that it is possible.
>         I guess that PostGIS 2.0 will soon become a standard, so if we
>         now want to make a bigger cleanup and new release of pgRouting
>         it's OK to require PostGIS 2.0 in my opinion. There haven't been
>         many questions about driving distance on the lists, so I assume
>         there are not so many users of this function either.
>         If you move it into "core" (which is a good idea), please don't
>         commit it into "master" branch for now.
>         I would propose to either make a different branch for that, that
>         we can merge later, or use "devel-2_0" branch, which already
>         contains code cleanup:
>         https://github.com/pgrouting/pgrouting/tree/devel-2_0
>         Daniel
>         On Tue, Jun 19, 2012 at 11:11 AM, Mario Basa
>         <mario.basa at gmail.com <mailto:mario.basa at gmail.com>> wrote:
>             Hi,
>             It really is possible now to take away CGAL from pgRouting
>             since st_concavehull of PostGIS 2 can create the same alpha
>             shape. I have already managed to compile diriving-dist
>             without CGAL installed by modifying the cmake files and
>             drivedist.c.
>             I used this:
>             select st_concavehull(st_collect(
>                st_geomfromewkt('srid=4326;POINT('||x1||'
>             '||y1||')')),0.7) from jp_2po_4pgr,
>                driving_distance('SELECT
>             id,source,target,cost,reverse_cost from jp_2po_4pgr
>                where
>             st_contains(ST_GeomFromEWKT(''SRID=4326;POLYGON((139 35,139
>             36,140 36,140 35,139 35))''),
>                the_geom) = true',156598,0.07,false,false) where id =
>             edge_id;
>             to create the drive time polygon in the attached screen
>             dump. The performance isn't so bad even with a 0.7 target
>             percent parameter for the concave hull.
>             I am planning to clean up routing_dd.sql and
>             routing_dd_wrapper.sql and start using the newer st_*
>             postgis functions.
>             Will there be any objections if I move routing_dd into core
>             instead of extra since it will now only use BOOST to compile.
>             Mario.
>             _______________________________________________
>             pgrouting-dev mailing list
>             pgrouting-dev at lists.osgeo.org
>             <mailto:pgrouting-dev at lists.osgeo.org>
>             http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>         Georepublic UG & Georepublic Japan
>         eMail: daniel.kastl at georepublic.de
>         <mailto:daniel.kastl at georepublic.de>
>         Web: http://georepublic.de <http://georepublic.de/>
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
More information about the pgrouting-dev mailing list
