[pgrouting-dev] DBSP first try problems
Stephen Woodbridge woodbri at swoodbridge.com
Fri Jun 29 09:59:26 PDT 2012
Hi Razequl,
I finally have some time to look at your code, but have run into a small
build problem.
woodbri at mappy:~/work/pgrouting-git/gsoc-bdsp$ git clone
git://github.com/zibon/pgrouting.git
Initialized empty Git repository in
/u/work/pgrouting-git/gsoc-bdsp/pgrouting/.git/
remote: Counting objects: 1930, done.
remote: Compressing objects: 100% (743/743), done.
remote: Total 1930 (delta 1189), reused 1882 (delta 1151)
Receiving objects: 100% (1930/1930), 685.37 KiB | 1112 KiB/s, done.
Resolving deltas: 100% (1189/1189), done.
woodbri at mappy:~/work/pgrouting-git/gsoc-bdsp/pgrouting$ cmake .
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- POSTGRESQL_EXECUTABLE is POSTGRESQL_EXECUTABLE-NOTFOUND
-- Found PostgreSQL: /usr/include/postgresql/8.3/server, /usr/lib/libpq.so
-- Boost version: 1.34.1
-- Found the following Boost libraries:
Boost headers were found here: /usr/include
Output directory for libraries is set to /usr/lib/postgresql/8.4/lib
-- Found PGROUTING_CORE core:
/home/woodbri/work/pgrouting-git/gsoc-bdsp/pgrouting/core/src
Installation directory for libraries is set to
/usr/lib/postgresql/8.4/lib and for SQL files is set to /usr/share/pgrouting
CMake Error at CMakeLists.txt:117 (SUBDIRS):
   subdirs Incorrect SUBDIRS command.  Directory: extra/trsp does not
exists.
-- Configuring done
woodbri at mappy:~/work/pgrouting-git/gsoc-bdsp/pgrouting$ ls extra/
bdsp  CMakeLists.txt  driving_distance  tsp
So you can see that there is no extra/trsp directory in your repository.
Do you need to add, commit and push that to your remote?
Also don't forget your report, its Friday again. :)
Thanks,
   -Steve
More information about the pgrouting-dev mailing list
