[pgrouting-dev] DBSP first try problems
Razequl Islam ziboncsedu at gmail.com
Fri Jun 29 18:46:04 PDT 2012
Hi Steve,
It is great that you got some time to review the code. I have trsp in my
local folder but I found it is not in the git. I will commit that again.
And yes, commenting trsp subdirs should work. Also as I have not done any
work on that folder, you should be able to review my work. All my codes are
in the bdsp folder.
Thanks for your time. I am waiting to learn more from you.
- Razequl
On Fri, Jun 29, 2012 at 11:10 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> OK, my temporary fix was to comment out the subdir:
> #SUBDIRS(extra/trsp)
> -Steve
> On 6/29/2012 12:59 PM, Stephen Woodbridge wrote:
>> Hi Razequl,
>> I finally have some time to look at your code, but have run into a small
>> build problem.
>> woodbri at mappy:~/work/**pgrouting-git/gsoc-bdsp$ git clone
>> git://github.com/zibon/**pgrouting.git<http://github.com/zibon/pgrouting.git>
>> Initialized empty Git repository in
>> /u/work/pgrouting-git/gsoc-**bdsp/pgrouting/.git/
>> remote: Counting objects: 1930, done.
>> remote: Compressing objects: 100% (743/743), done.
>> remote: Total 1930 (delta 1189), reused 1882 (delta 1151)
>> Receiving objects: 100% (1930/1930), 685.37 KiB | 1112 KiB/s, done.
>> Resolving deltas: 100% (1189/1189), done.
>> woodbri at mappy:~/work/**pgrouting-git/gsoc-bdsp/**pgrouting$ cmake .
>> -- The C compiler identification is GNU
>> -- The CXX compiler identification is GNU
>> -- Check for working C compiler: /usr/bin/gcc
>> -- Check for working C compiler: /usr/bin/gcc -- works
>> -- Detecting C compiler ABI info
>> -- Detecting C compiler ABI info - done
>> -- Check for working CXX compiler: /usr/bin/c++
>> -- Check for working CXX compiler: /usr/bin/c++ -- works
>> -- Detecting CXX compiler ABI info
>> -- Detecting CXX compiler ABI info - done
>> -- POSTGRESQL_EXECUTABLE is POSTGRESQL_EXECUTABLE-NOTFOUND
>> -- Found PostgreSQL: /usr/include/postgresql/8.3/**server,
>> /usr/lib/libpq.so
>> -- Boost version: 1.34.1
>> -- Found the following Boost libraries:
>> Boost headers were found here: /usr/include
>> Output directory for libraries is set to /usr/lib/postgresql/8.4/lib
>> -- Found PGROUTING_CORE core:
>> /home/woodbri/work/pgrouting-**git/gsoc-bdsp/pgrouting/core/**src
>> Installation directory for libraries is set to
>> /usr/lib/postgresql/8.4/lib and for SQL files is set to
>> /usr/share/pgrouting
>> CMake Error at CMakeLists.txt:117 (SUBDIRS):
>>   subdirs Incorrect SUBDIRS command.  Directory: extra/trsp does not
>> exists.
>> -- Configuring done
>> woodbri at mappy:~/work/**pgrouting-git/gsoc-bdsp/**pgrouting$ ls extra/
>> bdsp  CMakeLists.txt  driving_distance  tsp
>> So you can see that there is no extra/trsp directory in your repository.
>> Do you need to add, commit and push that to your remote?
>> Also don't forget your report, its Friday again. :)
>> Thanks,
>>   -Steve
>> ______________________________**_________________
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20120630/8c8af661/attachment.html>
More information about the pgrouting-dev mailing list
