[pgrouting-dev] Problems in Installing pgrouting
Stephen Woodbridge woodbri at swoodbridge.com
Thu May 17 16:45:07 EDT 2012
On 5/17/2012 4:31 PM, Jinfu Leng wrote:
> Hey,
> I am trying to install pgrouting, but get some problems:
> When I was running this command "cmake -DWITH_TSP=ON -DWITH_DD=ON", I
> get the error messages said "GAUL" and "Postgresql" are required. Then I
> tried to install "GAUL", and get the message that "s-lang" is required.
> I downloaded the source code of "s-lang", but did not figure out how to
> install it. I also checked "synaptic package manager", and found that
> "postgresql-8.4" was already existed.
> I am using Ubuntu 10.04, 64 bits.
Ok, you need to install some of the dev packages.
sudo apt-get install postgresql-server-dev-8.4
sudo apt-get install libslang2 libslang2-dev
You can use apt-cache search <string> to search for packages based on
<string> eg: apt-cache search slang
-Steve
More information about the pgrouting-dev mailing list
