[pgrouting-dev] Which versions of cgal, gaul and boost should be used to compile pgrouting on Ubuntu 12-4
Dave Potts dave.potts at pinan.co.uk
Thu Oct 25 06:29:31 PDT 2012
Hi
I am trying to add intergrate some code to add support for the K
shortest-path problem to pg route.
There are lots of branches in git archive
https://github.com/pgRouting/pgrouting.git which version is the most
stable?
I am aware that the default versin 1.05 does not appear to compile with
the current support libraries due to changes in the library api.  I have
no desire to repeat work thats already been done.
regards
Dave.
Dave Potts wrote:
> Hi,
> I am trying to build from source and I am getting compiler errors.
> Which  versions of boost, cgal and gaul should be used to build the
> pgrouting software?
> My build platform is 64 Ubuntu 12.4, gcc 4.6.3.
> Dave.
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
