[pgrouting-dev] Which versions of cgal, gaul and boost should be used to compile pgrouting on Ubuntu 12-4
Daniel Kastl daniel at georepublic.de
Thu Oct 25 18:09:33 PDT 2012
Hi Dave,
You're specifically asking about Ubuntu, right?
GAUL hasn't changed for ages and is not a problem. If you use Ubuntu you
can just install the package I made:
https://launchpad.net/~georepublic/+archive/pgrouting
CGAL is steadily upgraded in Ubuntu and there were often changes in paths
for example. I had to fix it depending on the Ubuntu release.
You can actually get the pgRouting package source from the repository above
with apt-get source and see which dependencies it has. You need to look
into debian/control file. It lists all versions as that Ubuntu release
requires.
Recently I used the master branch to build the packages, because there was
no release for a while.
There were various attempts to get everything cleaned up and working with
PostGIS 2.0. But it's something that needs several days of work without
being distracted by other tasks. It might also break backwards
compatibility, so it would be then a new major version.
Daniel
On Fri, Oct 26, 2012 at 12:25 AM, Ko Nagase (aka sanak)
<geosanak at gmail.com>wrote:
> Hi Dave,
> Which source did you use?
> pgrouting-1.05.tar.gz or git clone master branch ?
> I am afraid recent my pull request(
> https://github.com/pgRouting/pgrouting/pull/61) affect ubuntu build badly.
> Regards,
> 2012/10/25 Dave Potts <dave.potts at pinan.co.uk>
>> Hi,
>> I am trying to build from source and I am getting compiler errors.
>> Which  versions of boost, cgal and gaul should be used to build the
>> pgrouting software?
>> My build platform is 64 Ubuntu 12.4, gcc 4.6.3.
>> Dave.
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20121026/a7117dc6/attachment.html>
More information about the pgrouting-dev mailing list
