[pgrouting-dev] [pgRouting/pgrouting] 2d7e98: update some functions
Razequl Islam ziboncsedu at gmail.com
Sat Aug 24 02:43:11 PDT 2013
Hi Steve,
Thanks for the information. As I have lost some days, I am working hard to
make that up. I am still having some issues with the test environment. I am
fixing those and hopefully this will be completed within two-three days. I
will then invite you to run the program using some sample files and have a
feel of that. Once it is done, I will start to write codes for taking input
from database and feed it to the algorithm. There are some design issues
and so I will need help from you and Daniel. I have started looking at the
codes for TSP and DARP as they have similarity with VRP. As for push_back
issue, I will follow your suggestion. May be we implement the copy
constructor of the class as push_back calls the copy constructor.
- Razequl
On Sat, Aug 24, 2013 at 1:52 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Hi Razequl,
> Thank you for checking your code. I just had a "quick" look over it and
> you seem to be making good progress. I see you are starting to integrate
> you code into pgRouting. Is it safe to assume that you have it working to
> your satisfaction in yout tester environment?
> One issue that we have run into with out pgrouting code is that you should
> not push_back large objects on to a std::vector as this seems to allocate
> memory for a copy and it tends to fail. We have worked around this in other
> code by pushing a reference or point onto the std::vector an then making
> sure we new() and delete() the objects as appropriate.
> These seems to work fine outside the postgresql environment, but tends to
> be problematic in postgresql and it seems to be random whether it works or
> not.
> So just keep this in mind as you are integrating code.
> Thanks,
>   -Steve
> On 8/23/2013 3:25 PM, zibon wrote:
>>    Branch: refs/heads/gsoc-vrp
>>    Home:   https://github.com/pgRouting/**pgrouting<https://github.com/pgRouting/pgrouting>
>>    Commit: 2d7e9858d029d0fbbc41003336217b**0490edb437
>>        https://github.com/pgRouting/**pgrouting/commit/**
>> 2d7e9858d029d0fbbc41003336217b**0490edb437<https://github.com/pgRouting/pgrouting/commit/2d7e9858d029d0fbbc41003336217b0490edb437>
>>    Author: zibon <ziboncsedu at gmail.com>
>>    Date:   2013-08-23 (Fri, 23 Aug 2013)
>>    Changed paths:
>>      M src/vrp_basic/src/VRP_Solver.**cpp
>>      M src/vrp_basic/src/VRP_Solver.h
>>    Log Message:
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130824/aeba8d66/attachment.html>
More information about the pgrouting-dev mailing list
