[pgrouting-dev] Witch dev branch to use
Stephen Woodbridge woodbri at swoodbridge.com
Mon Aug 26 13:03:44 PDT 2013
Agreed all development going forward will happen in the develop branch
and at stable points this will get merged back into master. Think of
master as where we drop stable releases, it is currently at something
like 1.05+ and when 2.0 gets released, it will get merged into master to
update that to the release. Otherwise nothing should be getting done in
master. all the releases are tags in the develop branch to mark
significant states in the process.
-Steve
On 8/26/2013 3:31 PM, Daniel Kastl wrote:
> On Tue, Aug 27, 2013 at 4:06 AM, Dave Potts <dave.potts at pinan.co.uk
> <mailto:dave.potts at pinan.co.uk>> wrote:
>     The page
>     http://docs.pgrouting.org/dev/__doc/src/installation/index.__html#build-from-source
>     <http://docs.pgrouting.org/dev/doc/src/installation/index.html#build-from-source>,
>     lists 5 different branches,  if I want to do some development work,
>     which one should I use?
> Hi Dave,
> These are not different branches but tags, that can be downloaded.
> If you want to develop, then you best clone the Git repository and use
> branch "develop".  There is only one of this name.
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
