[pgrouting-dev] Pull Request #213
Stephen Woodbridge woodbri at swoodbridge.com
Mon Dec 2 11:58:24 PST 2013
strk, Vicky,
I tried to integrate this pull request into my local develop branch but
the test is failing. I suspect that it only needs the test results updated.
src/common/test/createTopology-any-01.test  -- test file
src/common/test/createTopology-any-01.rest  -- result file
I can update the result file if you can confirm that the command is
actually working as expected. Then I will commit and push the change
into develop and into develop-2_0_1
One concern is whether we need to dynamically change the reporting level
when this executes so we don't spew noisy messages that will only
confuse the users.
If I have time tonight, I'll take a closer look at the results myself.
Thanks,
   -Steve
More information about the pgrouting-dev mailing list
