[pgrouting-dev] [pgrouting-users] pgr_createTopology
Stephen Mather stephen at smathermather.com
Mon Dec 2 22:22:27 PST 2013
Resubmitted on the correct branch.  In nominal tests here (not a full
rebuild but just a loading of that sql file), it seems to retain node
numbers very nicely.
Best,
Steve
On Tue, Dec 3, 2013 at 12:15 AM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Stephen,
> Thanks for looking into this!
> I just wanted to mention that it would be better, if a pull request would
> be in "develop" branch (I already didn't look careful recently and just
> clicked "merge pull request" accidentally and it was merged into master
> branch).
> So in general making changes in "develop" branch is better, because
> "develop" might be also ahead of "master" anyway.
> Daniel
> On Tue, Dec 3, 2013 at 11:54 AM, Stephen Mather <stephen at smathermather.com
> > wrote:
>> I don't know if I did this correctly, but:
>> https://github.com/pgRouting/pgrouting/pull/221
>> On Sat, Nov 30, 2013 at 4:43 PM, Stephen Mather <
>> stephen at smathermather.com> wrote:
>>> Done.  Issue #220 <https://github.com/pgRouting/pgrouting/issues/220>.
>>> Thanks,
>>> Best,
>>> Steve
>>> On Sat, Nov 30, 2013 at 2:52 PM, Stephen Mather <
>>>> Cool, I'll write a ticket.  It would be mostly useful in the case of
>>>> e.g. tutorial development.
>>>> Best,
>>>> Steve
>>>> On Sat, Nov 30, 2013 at 2:46 PM, Stephen Woodbridge <
>>>> woodbri at swoodbridge.com> wrote:
>>>>> On 11/30/2013 2:18 PM, Stephen Mather wrote:
>>>>>> Is pgr_createTopology deterministic in how it numbers nodes in a built
>>>>>> topology?
>>>>> Stephen,
>>>>> What do you mean by this?
>>>>> If you build a topology on the same edge table twice, do we guarantee
>>>>> that the nodes numbers will be identical?
>>>>> I think the answer is NO, on line:303 of src/common/sql/pgrouting_topology.sql
>>>>> there is no "order by" clause. This would need to be added to make it
>>>>> deterministic because relational set theory does not guarantee order of
>>>>> records in a query without explicitly including and "order by" clause.
>>>>> Write a bug if you think this is needed and state why.
>>>>> Thanks,
>>>>>   -Steve
>>>>> _______________________________________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20131203/677a8608/attachment.html>
More information about the pgrouting-dev mailing list
