[pgrouting-dev] GSoC partitioning project
Mukul priya mukul2047 at gmail.com
Fri Jul 5 10:44:42 PDT 2013
Ok. got it now.
I think i am clear with the basic skeleton , will try to code it this
weekend , will post doubts directly on this list regarding c or c++ issues .
thanks.
On Fri, Jul 5, 2013 at 10:59 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 7/5/2013 1:00 PM, Mukul priya wrote:
>> do we need to retrieve all the edges that are lying totally or
>> partially in that partition or even if we retrieve only those edges
>> that are directly  connected to the source node that is load only
>> those edges that have one of its node as source node.
> When we load a partition we load all of the edges that have at least one
> node in that partition. That means if both nodes are in the partition we
> load it, and if only the target or the source node are in the partition
> we load it. Once the partition is load we make it as loaded in the bit
> array and we never load it again.
> On 7/5/2013 1:11 PM, Mukul priya wrote:
>> we have the partition_id and the node_id (of source node) so we can
>> retrieve only those edges that have one of their nodes as source
>> node. So two conditions will arise here 1) That edge might completely
>> lie inside that partition ( as u sadi above ) 2) Its a boundary edge
>> , in that case if the algorithm follws this edge then we again have
>> to check whether the partition( using target_partiton_id) in which
>> the target_node of this edge is  lying is loaded or not.
> So when you are solving the graph and we are at some node A and it
> connects via edges to nodes B, C, D.
> You will need to check if A.partition != 0 or B.partition !=0 then check
> if the partition is loaded or not and load it if needed.
> -Steve
> ______________________________**_________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130705/597310a0/attachment.html>
More information about the pgrouting-dev mailing list
