[pgrouting-dev] Class Skeleton for VRP solver
Johannes Scholz johannes.scholz at researchstudio.at
Mon Jul 8 02:10:30 PDT 2013
Dear Razequl,
Sorry for being that late -  but I had an in depth look at your header file
and generally you had have done a good job in abstracting the VRP. Hence
this serves as starting point four your implementation! Generally I follow
Steve's suggestions posted on the gist page on how to document the standard
usage of the objects created, in order to get an impression on how to use
them properly.
Generally I think you made a good decision in looking at VRPH first before
actually starting to implement things J
Thanks very much and all the best
Johannes
Von: Razequl Islam [mailto:ziboncsedu at gmail.com]
Gesendet: Samstag, 06. Juli 2013 13:29
An: Daniel Kastl
Cc: Johannes Scholz; Stephen Woodbridge; pgRouting developers mailing list
Betreff: Re: Class Skeleton for VRP solver
Thanks Daniel.
I have put it in Gist. Here is the link:
https://gist.github.com/zibon/5939625
-Razequl
On Sat, Jul 6, 2013 at 8:07 AM, Daniel Kastl <daniel at georepublic.de> wrote:
I Razequl,
What about placing files like this in Gist: https://gist.github.com/
Good to read and possible to make comments right to the file.
Daniel
On Sat, Jul 6, 2013 at 5:17 AM, Razequl Islam <ziboncsedu at gmail.com> wrote:
Sorry,
I forgot to attach the file which is attached now.
-Razequl
On Sat, Jul 6, 2013 at 2:06 AM, Razequl Islam <ziboncsedu at gmail.com> wrote:
I am trying to develop the classes for the VRP solution. I was going through
some relevant papers and some codes from VRPH
(https://projects.coin-or.org/VRPH) and based on that I have come up with
the attached skeleton. I am going to add it to git. I have put all the
classes in one header, but they can be put in several headers and cpp. I am
bit confused on that.
Please have a look at the classes. I have tried to give meaningful names.
Your feedback will be very much helpful.
- Razequl
Georepublic UG & Georepublic Japan
eMail:  <mailto:daniel.kastl at georepublic.de> daniel.kastl at georepublic.de
Web:  <http://georepublic.de/> http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130708/9e8ac76f/attachment.html>
More information about the pgrouting-dev mailing list
