[pgrouting-dev] Fixes for Bidirectional code just checked in
Stephen Woodbridge woodbri at swoodbridge.com
Wed Jun 5 12:08:00 PDT 2013
Hi Alec,
What branch are you working off of? sew-devel-2_0 or develop?
Because I checked in those fixes 4 days ago:
https://github.com/pgRouting/pgrouting/blob/develop/src/bd_astar/src/BiDirAStar.cpp
Look at line 72
Please make sure you are using branch "develop"
Thanks,
   -Steve
On 6/5/2013 10:13 AM, Alec Gosse wrote:
> It would seem that it was simply running out of memory due to giant default vector resize requests. Adding
> m_vecEdgeVector.reserve(edge_count);
> before the loop calling addEdge(..) in the construct_graph function seems to do the trick. Probably best to do m_vecNodeVector.reserve(maxNode) as well, just for good measure;
> I recall seeing something similar to this discussed, but perhaps it was somewhere else in the code.
> Alec
> On Jun 4, 2013, at 4:34 PM, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>> On 6/4/2013 3:53 PM, Alec Gosse wrote:
>>> Hello,
>>> I've just pulled from the develop branch and built fresh and I'm
>>> getting a server crash from pgr_bdastar. If I run exactly the same
>>> thing using pgr_astar, it works. This is using postgres 9.2.4 and
>>> postgis 2.0.3 from Homebrew on Mac 10.8.3
>> I'm using pg9.2.4 and postgis 2.0.x or 2.1.0beta3dev and I fixed these issues I thought. Evidently not.
>>> I'm still working on a bulk routing function using bdastar, but just
>>> realized that the regular version was crashing without my
>>> modifications. I'm happy to try to track this down, but have little
>>> knowledge of how to debug within postgresql. Any pointers would be
>>> appreciated.
>> OK, start by uncommenting #define DEBUG 1 in both the C and C++ code. Then add more DBG('I got here message\n"). In the C++ code these messages get written to a file '/tmp/sew-debug' and you can do a tail -f on that in another window to see your progress.
>> This is likely a issue in the C++ code but it may also be something systemic about the way we are integrating code. If you build your own postgresql you might want to rebuild it with --enable-cassert option to configure which will put the database backend into a more rigorous memory check mode.
>> That is a start, I would be appy to help more if I can.
>> Thanks,
>>   -Steve
>>> Best, Alec
>>> On Jun 1, 2013, at 2:13 PM, Stephen Woodbridge
>>>> Hi all,
>>>> I think I have just submitted changes to the bidirectional dijkstra
>>>> and astar routines the resolve the server crashes we were seeing.
>>>> This closes on major outstanding bug against 2.0.
>>>> Razequl,
>>>> I made two simple changes to your code BiDirDijkstra.cpp and the
>>>> astar version:
>>>> 1. in BiDirDijkstra::initall I add: m_vecNodeVector.reserve(maxNode
>>>> + 1);
>>>> 2. in BiDirDijkstra::bidir_dijkstra I move the call to
>>>> initall(maxNode); to before construct_graph(edges, edge_count,
>>>> maxNode);
>>>> This does two major things:
>>>> 1. std::vector doubles the size of the array every time it needs to
>>>> increase its size and then needs to copy the old data to the new
>>>> area.
>>>> 2. reserve() pre allocates all the memory we need once, which avoid
>>>> realloc memory fragmentation and avoids the copy each time it
>>>> reallocs so this improves performance.
>>>> Anytime you know how much space you are going to need you should
>>>> reserve it up front.
>>>> So things look good for now.
>>>> Thanks, -Steve _______________________________________________
>>>> pgrouting-dev mailing list pgrouting-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>> _______________________________________________ pgrouting-dev mailing
More information about the pgrouting-dev mailing list
