[pgrouting-dev] Having problems under standing the distance matrix of TSP in respect to route network pgroute version 2, possible solution
Dave Potts dave.potts at pinan.co.uk
Sat Jun 15 11:34:27 PDT 2013
On 15/06/13 14:28, Stephen Woodbridge wrote:
Nice Idea, but one of the problems I have is that I am VERY lazy!
When I create a source/target/cost table I only tend to populate it with
existing routes, so if I have path at cost of 42 betweens nodes 2 and 3
I will create an entry  like
     2 3 42
I have no desire to create an entry for journey between nodes 5 6 that
does not exist or having to provide  a value for journey between myself
and myself eg a journey from node 2 to node 2,  I think the suggested
solution would require me to create entries like
    2 2 0
    5 6 0  etc
So I had a crack at writing a function based on Steves original
screenplay.  I think it needs a lot more work,  when I create the
temporary tables,  I get a diagnostic from psql saying that its created
a table.  There must be a better way of doing it
Its invoked as
select mktsparray(' select source,target ,cost  from edge_table2');
-- Make a distance matrix for the traveling salesman  problem
-- Input is an sql string that provides source, target and the cost
-- of getting between them
CREATE or REPLACE FUNCTION mktsparray(tag_name text) RETURNS float []
     LANGUAGE plpgsql
     AS $$
DECLARE
         ret_array float [][];
         array_size integer;
         tsp_details record;
BEGIN
         ret_array := null;
         -- create a copy of the source
         EXECUTE 'DROP TABLE IF EXISTS tsp_src';
         EXECUTE 'DROP TABLE IF EXISTS tsp_map';
         create temporary table tsp_src ( id serial not null,source
integer not null,
                                 target integer not null,  cost float
not null);
         -- create a tsp node to matrix lookup table
         create temporary table tsp_map ( id serial not null primary
key, nid integer);
         EXECUTE 'insert into tsp_src (source, target, cost)'|| tag_name;
         insert into tsp_map (nid) select nid from (select distinct
source as nid from edge_table2 union select distinct target as nid from
edge_table2) as foo;
         -- should generate a matrix count(*) X count(*) of tsp_map
         select count(*) INTO array_size from tsp_map;
         -- by default populate the return results with zero, so any
unknown
         -- routes will not be listed
         ret_array :=array_fill(0,ARRAY  [ array_size,array_size]);
         -- Loop trough  the input looking for any listed routes
         FOR tsp_details IN EXECUTE
                         'select  c.nid as src ,b.nid as tar,a.cost as cos
                                 from tsp_src a, tsp_map b, tsp_map c
                                 where a.target= b.nid and a.source=
c.nid and a.cost > 0
                                 group by b.id,c.id,a.cost' LOOP
ret_array[tsp_details.src][tsp_details.tar]:=tsp_details.cos;
         END LOOP;
         return ret_array;
END
> Dave,
> I thought a lot about this problem before coming up with the matrix.
> The problem really boils down to how do you define your data that you
> want to fetch with "select * from xyz", ie: your inputs and what you
> need to solve TSP, ie: your outputs. In this case a symmetrix NxN
> matrix that is fully populated.
> One idea I had was to structure xyz something like:
> node_a, node_b, cost
> but then you have to count the distinct nodes, and create a map to
> indices and a reverse map as you as you mention. But this is all
> pretty trivial to do in SQL.
> create temporary table xyz_map (
>   id serial not null primary key,
>   nid integer
> insert into xyz_map values (nid) select nid from (
>   select distinct node_a as nid from xyz
>   union
>   select distinct node_b as nid from xyz
> ) as foo;
> select array_agg(row) as matrix from (
>   select a.id, array_agg(cost) as row
>     from xyz a, xyz_map b, xyz_map c
>     where a.node_a=b.nid and a.node_b=c.nid
>     group by a.id
>     order by c.id
>   ) foo order by foo.id;
> I have not tested this, but I think it is close to what you would
> work. I would then do some checking of matrix to make sure it is
> symmetric and filled out.
> -Steve
> On 6/15/2013 1:37 AM, Dave Potts wrote:
>> On 14/06/13 14:19, Daniel Kastl wrote:
>> I can try and have a play, my problem being that I am more a C/java
>> programmer than an sql programmer.  I prefer to deal with standard sql
>> constructs rather that data base specfic stuff.
>> I can see why you got for the matrix solution, if avoid all those
>> node/hash lookup problems.
>> If coding an select * from xyz solution , you have to deal with the case
>> that a node may be any number in the range 1-32^2 and that has to be
>> mapped on to an array of given size by using some type of hashing
>> function and a reverse lookup has to be done on the return.
>> The store procedure has its attractions because its version neutral, it
>> will work as well on linix box as well as a Windoz box.
>> I see what I can come up with.
>> DAve.
>>> On Fri, Jun 14, 2013 at 10:07 PM, Stephen Woodbridge
>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>>     Hi Dave,
>>>     I'm not totally opposed to this, but I would like to discuss how
>>>     you plan to structure the data and what your query would look like.
>>>     There is another possibility that I like better and that would be
>>>     to write stored procedure that takes you sql query and returns a
>>>     matrix.
>>>     matrix[][] pgr_matrix(sql text)
>>>     Then you can do something like:
>>>     select * from pgr_tsp(pgr_matrix('select * from matrix_table'),
>>> 27);
>>> This idea I really like, because we might also be able to use it then
>>> for Razequl's VRP solver.
>>> Daniel
>>> Georepublic UG & Georepublic Japan
>>> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
>>> Web: http://georepublic.de <http://georepublic.de/>
>>> pgrouting-dev mailing list
>>> pgrouting-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
