[pgrouting-dev] testing TSP example fails
Stephen Woodbridge woodbri at swoodbridge.com
Sat Jun 15 16:00:46 PDT 2013
OK, those are benign for some reason postgres is not consistent about
the way it issues NOTICE statements on different versions of so it those
are false  failures.
If you want to file a ticket on the failure with enough info on how to
reproduce it, I'll look at it when I get back.
Thanks,
   -Steve
On 6/15/2013 5:27 PM, Stephen Mather wrote:
> Ok, definitely some failures:
> $stats = {
>             'src/apsp_johnson/test/test.conf' => [
>                                                      'comment' => 'APSP
> Johnson test for any versions.',
> 'src/apsp_johnson/test/apsp_johnson-any-00.test' => 'Passed'
>             'src/apsp_warshall/test/test.conf' => [
>                                                       'comment' => 'APSP
> Warshall test for any versions.',
> 'src/apsp_warshall/test/apsp_warshall-any-00.test' => 'Passed'
>             'src/astar/test/test.conf' => [
>                                               'comment' => 'astar test
> for any versions.',
> 'src/astar/test/spas-any-00.test' => 'Passed',
> 'src/astar/test/spas-any-01.test' => 'Passed'
>             'src/bd_astar/test/test.conf' => [
>                                                  'comment' =>
> 'Bi-directional AStar test for any versions.',
> 'src/bd_astar/test/bd_astar-any-01.test' => 'Passed',
> 'src/bd_astar/test/bd_astar-any-02.test' => 'Passed',
> 'src/bd_astar/test/bd_astar-any-03.test' => 'Passed',
> 'src/bd_astar/test/bd_astar-any-04.test' => 'Passed',
> 'src/bd_astar/test/bd_astar-any-05.test' => 'Passed',
> 'src/bd_astar/test/bd_astar-any-06.test' => 'Passed'
>             'src/bd_dijkstra/test/test.conf' => [
>                                                     'comment' =>
> 'Bi-directional Dijkstra test for any versions.',
> 'src/bd_dijkstra/test/bd_dijkstra-any-01.test' => 'Passed',
> 'src/bd_dijkstra/test/bd_dijkstra-any-02.test' => 'Passed',
> 'src/bd_dijkstra/test/bd_dijkstra-any-03.test' => 'Passed',
> 'src/bd_dijkstra/test/bd_dijkstra-any-04.test' => 'Passed',
> 'src/bd_dijkstra/test/bd_dijkstra-any-05.test' => 'Passed',
> 'src/bd_dijkstra/test/bd_dijkstra-any-06.test' => 'Passed'
>             'src/common/test/test.conf' => [
>                                                'comment' =>
> 'pgr_createTopology, pgr_analyzegraph, and pgr_analyzeOneway tests for
> any versions.',
> 'src/common/test/common-any-01.test' => 'FAILED: 1,3d0
> < psql:src/common/test/common-any-01.test:1: NOTICE:  table
> "vertices_tmp" does not exist, skipping
> < CONTEXT:  SQL statement "DROP TABLE IF EXISTS vertices_tmp"
> < PL/pgSQL function pgr_createtopology(character varying,double
> precision,character varying,character varying) line 48 at SQL statement
> 6c3
> precision,character varying,character varying) line 49 at SQL statement
>  > PL/pgSQL function "pgr_createtopology" line 49 at SQL statement',
> 'src/common/test/common-any-02.test' => 'Passed',
> 'src/common/test/common-any-03.test' => 'Passed',
> 'src/common/test/common-any-04.test' => 'FAILED: 3c3
> < PL/pgSQL function pgr_nodenetwork(text,text,text,text,double
> precision) line 23 at SQL statement
>  > PL/pgSQL function "pgr_nodenetwork" line 23 at SQL statement
> 9c9
> precision) line 58 at SQL statement
>  > PL/pgSQL function "pgr_nodenetwork" line 58 at SQL statement
> 12c12
> precision) line 71 at EXECUTE statement
>  > PL/pgSQL function "pgr_nodenetwork" line 71 at EXECUTE statement
> 62c62
> 'src/common/test/versionless-any-01.test' => 'Passed'
>             'src/dijkstra/test/test.conf' => [
>                                                  'comment' => 'Dijkstra
> 'src/dijkstra/test/spd-any-00.test' => 'Passed',
> 'src/dijkstra/test/spd-any-01.test' => 'Passed',
> 'src/dijkstra/test/spd-any-02.test' => 'Passed',
> 'src/dijkstra/test/spd-any-03.test' => 'Passed'
>             'src/driving_distance/test/test.conf' => [
> 'comment' => 'Driving Distance test for any versions.',
> 'src/driving_distance/test/drivingdistance-any-00.test' => 'Passed'
>             'src/kdijkstra/test/test.conf' => [
> 'src/kdijkstra/test/kdijkstra-any-01.test' => 'Passed',
> 'src/kdijkstra/test/kdijkstra-any-02.test' => 'Passed'
>             'src/ksp/test/test.conf' => [
>                                             'comment' => 'KSP test for
> any versions.',
> 'src/ksp/test/ksp-any-01.test' => 'Passed',
> 'src/ksp/test/ksp-any-02.test' => 'Passed'
>             'src/trsp/test/test.conf' => [
>                                              'comment' => 'TRSP test for
> any versions.',
> 'src/trsp/test/trsp-any-00.test' => 'Passed',
> 'src/trsp/test/trsp-any-01.test' => 'Passed',
> 'src/trsp/test/trsp-any-02.test' => 'Passed',
> 'src/trsp/test/trsp-any-03.test' => 'Passed'
>             'src/tsp/test/test.conf' => [
>                                             'comment' => 'TSP test for
> any versions.',
> 'src/tsp/test/tsp-any-00.test' => 'Passed',
> 'src/tsp/test/tsp-any-01.test' => 'Passed',
> 'src/tsp/test/tsp-any-02.test' => 'Passed'
>             'z_crash' => 0,
>             'z_fail' => 2,
>             'z_pass' => 35
> On 06/15/2013 05:09 PM, Stephen Mather wrote:
>> Hmm.  I did a clone w -b develop, so I never did a checkout of the
>> repository after the clone.  Also didn't configure the docs
>> dependencies.  Otherwise, it looks the same.  About to rerun...
>> Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>>> If you are in the pgrouting git source tree like:
>>> git clone git://github.com/pgRouting/pgrouting.git
>>> cd pgrouting
>>> git checkout develop
>>> cat tools/doit        # this is my build script, it may not work for you
>>> tools/doit
>>> tools/test-runner.pl  # this will run all the tests
>>> The test script make a test database, loads the data and runs the tests.
>>> If you look in src/tsp/test
>>> CMakeLists.txt   tsp-any-00.rest  tsp-any-01.test  tsp-any-03.rest
>>> test.conf        tsp-any-00.test  tsp-any-02.rest  tsp-any-03.test
>>> tsp-any-00.data  tsp-any-01.rest  tsp-any-02.test
>>> createdb runtests
>>> psql runtests -c "create extension postgis"
>>> psql runtests -c "create extension pgrouting"
>>> psql runtests -f src/tsp/test/tsp-any-00.data  # load some data
>>> psql runtests -A -t -f src/tsp/test/tsp-any-00.test
>>> psql runtests -A -t -f src/tsp/test/tsp-any-01.test
>>> psql runtests -A -t -f src/tsp/test/tsp-any-02.test
>>> psql runtests -A -t -f src/tsp/test/tsp-any-03.test
>>> The output of each command should be the same as *.rest file.
>>> -Steve
>>> On 6/15/2013 4:39 PM, Stephen Mather wrote:
>>>> Ubuntu 12.04LTS
>>>> Postgis 2.0.1 r9979
>>>> GEOS 3.3.8-capi-1.7.8
>>>> proj 4.8.0
>>>> gdal 1.9.2
>>>> Libxml  2.7.8
>>>> pgr_version ()
>>>> 2.0.0-Dev
>>>> V2.0.0-alpha,31,15ac46d,feature-travis,1.46.1
>>>> When I run tests, it fails on every test w function not found.  Do I
>>>> need to prep the database in any way to run the tests?
>>>> Stephen Mather <stephen at smathermather.com> wrote:
>>>>> I have not tried tests yet but have have run astar and djikstra w
>>>>> no problem.  When does vacation start... I can run tests asap...  :)
>>>>>> On 6/15/2013 2:44 PM, Stephen Mather wrote:
>>>>>>> Hi All,
>>>>>>> More TSP for today.  In testing the example in the docs against the
>>>>>>> example data, I get what is to me a cryptic error:
>>>>>>> SELECT * FROM pgr_tsp('SELECT id AS source_id, x, y FROM
>>>>>>> vertex_table','2,7,11',7);
>>>>>>> ERROR:  Error TSP fail to findEulerianPath, check your distance
>>>>>>> matrix
>>>>>>> is valid.
>>>>>> This typically means there is something bad happening in the distance
>>>>>> matrix that is getting passed to the TSP function. Hmmm.
>>>>>> I would start with can you run the test cases or do they fail on your
>>>>>> system.
>>>>>> What OS system and versions of stuff are you running?
>>>>>> There TSP solution for 3 points is a triangle, it is a trivial case
>>>>>> where the input is the output. I thought is tested for that case but
>>>>>> maybe not.
>>>>>> BTW, I will be away on vacation without net access through June
>>>>>> 25th, so
>>>>>> I will not be much help until I get back.
>>>>>> -Steve
>>>>>>> ********** Error **********
>>>>>>> matrix is
>>>>>>> valid.
>>>>>>> SQL state: XX000
>>>>>>> I get an entirely different error against my OSM data, but one
>>>>>>> error at
>>>>>>> a time... .
>>>>>>> Best,
>>>>>>> Steve
>>>>>>> _______________________________________________
>>>>>>> pgrouting-dev mailing list
>>>>>>> pgrouting-dev at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
