[pgrouting-dev] Traveling salesman problem where cost <> reverse cost
Stephen Woodbridge woodbri at swoodbridge.com
Sat Jun 15 16:24:22 PDT 2013
On 6/15/2013 5:21 PM, Dave Potts wrote:
> Hi Stephen,
> I will add some tests to that code I wrote.
> Are you aware of a tsp algorithm that handles an issue when the cost and
> reverse cost for traveling between two nodes are different?
Yes it is called ATSP or asymmetric TSP. I would like to find code and
implement that for pgrouting 2.1.
google: asymmetric tsp approximation
http://faculty.cs.tamu.edu/chen/courses/cpsc669/f2005/reading/chrisp.pdf
-Steve
More information about the pgrouting-dev mailing list
