[pgrouting-dev] library versions
Daniel Kastl daniel at georepublic.de
Thu Jun 27 19:27:10 PDT 2013
Hi Stephen,
I wrote TBD, because I have to figure out first what would be the minimum
required version.
But trying to find this out is not so much fun ;-)
There is currently only CMake that requires a rather new version.
The rest doesn't seem to be a problem. So I'm not sure I want to spend much
time in trying to compile with ancient library versions.
We try to make pgRouting work with the recommended PostgreSQL versions of
PostGIS, see the matrix:
http://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
So far I had no version issues (except CMake) with dependencies and I have
created packages for Ubuntu 12.04, 12.10 and 13.04
This is the Debian control file to create the packages, which lists the
required libraries:
https://github.com/pgRouting/pgrouting-build/blob/master/debian/control
Daniel
On Fri, Jun 28, 2013 at 11:07 AM, Stephen Mather
<stephen at smathermather.com>wrote:
> In the documentation for compilation, several of the library version are
> listed as TBD-- any guesses/recommendations (known versions that work) for
> those libraries?  What does a typical (in Steve's case) debian build look
> like library-wise?
> Thanks,
> Best,
> Steve
> ______________________________**_________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130628/012fceb6/attachment.html>
More information about the pgrouting-dev mailing list
