[pgrouting-dev] pgRouting 2.0 Update
Daniel Kastl daniel at georepublic.de
Tue Mar 12 22:47:52 PDT 2013
> Currently, only sql and src are populated, but the basic structure is
> important as we move forward. Adding a new algorithm is just a matter of
> creating the tree and adding various CMakeFiles.txt files in each level of
> the tree and these can basically just mirror any of the parallel branches
> in the tree. When we start adding doc and tests I'll have to do some more
> work on the cmake files, but that can wait till I actually can install and
> test something.
Before you think about the "doc" let me know, because I already have
something in mind.
I want to automatically build it with Sphinx so the website will be updated
automatically.
The typical problem with documentation are different versions. But maybe
that'S solved anyway if we keep it in the source tree.
Well, this can wait for April, I think.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130313/75db442a/attachment.html>
More information about the pgrouting-dev mailing list
