[pgrouting-dev] pgRouting 2.0 Update
Stephen Woodbridge woodbri at swoodbridge.com
Wed Mar 13 21:32:38 PDT 2013
Hi all,
Some great progress tonight. I was able to do a clean clone, build, and
install on a debian squeeze box with postgresql 8.4 and postgis 1.5
installed. I had to install cmake version 2.8.10.2 and gaul from source.
And I was able to install a simple graph and run some simple tests on
the trsp algorithm. I installed the test files in the trsp/test directory.
I can also build under mingw64, but I only have pg 9.2 and postgis 2.0
installed to test on and that will need some source changes.
So tomorrow, I need to think about what the next steps need to be and
look at the sql code.
-Steve
On 3/13/2013 6:53 PM, Stephen Woodbridge wrote:
> On 3/13/2013 6:12 PM, Stephen Woodbridge wrote:
>> Hi all,
>> I just pushed today's changes into my branch and only have run the build
>> on Linux, but I in theory have it coded to install as an extension or
>> not on pre postgresql 9.1.
>> None of the SQL code has been changed yet, so you should be able to do a
>> create extension to install it, it will probably fail because of
>> function names and stuff like that.
>> My next steps are:
>> * pull it back to mingw and see what breaks there and fix that
>> * install it on my postgresql 8.3/8.4 and see if it works there
>> * if it does, I'll create TAG or branch to keep a stable version at that
>> state
>> * start looking into the issues of running it with postgis 2.x and pg9.2
> Corrected!
> A couple of points for anyone that wants to play with this. The first
> being don't expect too much this is still a work in progress and has not
> been tested.
> git clone git at github.com:pgRouting/pgrouting.git
> cd pgrouting
> # Doh! I forgot this most important step ##############
> git checkout sew-devel-2_0
> # this requires cmake version 2.8.10
> cmake  -DWITH_TSP=ON -DWITH_DD=ON .
> make
> # assuming everything worked with out any issues you can see
> # the install targets here
> ls lib
> librouting_dd.so  librouting_tsp.so     pgrouting--1.0.7.sql.in  README
> librouting.so     pgrouting--1.0.7.sql  pgrouting.control
> # make install will place *.so into pg_config --pkglibdir
> # and *.{sql,control} will get placed in either:
> # `pg_config --sharedir`/extension/  >= pg 9.1
> # or /usr/share/pgrouting/            < pg 9.1
> sudo make install
> Have fun,
>    -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
