[pgrouting-dev] pgRouting 2.0 Update
    Frédéric Bonifas
    fredericbonifas at gmail.com
    Mon Mar 18 04:09:20 PDT 2013
Fixed, sorry for the noise, the problem came from using cmake 2.8.7
instead of 2.8.10
Best
Frédéric Bonifas
2013/3/18 Frédéric Bonifas <fredericbonifas at gmail.com>:
> Hi,
> Thank you for that Steve.
> I have pg 9.1.8 and 2.0 installed and I am trying to build the
> sew-devel-2_0 branch. When I run "cmake  -DWITH_TSP=ON -DWITH_DD=ON ."
> I get the following errors :
> CMake Error: Target astar has dependency information when it shouldn't.
> Your cache is probably stale. Please remove the entry
>   astar_LIB_DEPENDS
> from the cache.
> CMake Error: Target dijkstra has dependency information when it shouldn't.
>   dijkstra_LIB_DEPENDS
> from the cache.
> CMake Error: Target shooting_star has dependency information when it shouldn't.
>   shooting_star_LIB_DEPENDS
> from the cache.
> CMake Error: Target trsp has dependency information when it shouldn't.
>   trsp_LIB_DEPENDS
> from the cache.
> Looking at the CMakeCache.txt file, these lines are :
> //Dependencies for target
> astar_LIB_DEPENDS:STATIC=
> dijkstra_LIB_DEPENDS:STATIC=
> routing_LIB_DEPENDS:STATIC=
> shooting_star_LIB_DEPENDS:STATIC=
> trsp_LIB_DEPENDS:STATIC=
> I don't know how to fix these errors. Would deleting these lines be ok ?
> Thanks in advance
> Frédéric Bonifas
> +33672652807 skype:fredericbonifas
> 2013/3/13 Stephen Woodbridge <woodbri at swoodbridge.com>:
>> On 3/13/2013 6:12 PM, Stephen Woodbridge wrote:
>>> Hi all,
>>> I just pushed today's changes into my branch and only have run the build
>>> on Linux, but I in theory have it coded to install as an extension or
>>> not on pre postgresql 9.1.
>>> None of the SQL code has been changed yet, so you should be able to do a
>>> create extension to install it, it will probably fail because of
>>> function names and stuff like that.
>>> My next steps are:
>>> * pull it back to mingw and see what breaks there and fix that
>>> * install it on my postgresql 8.3/8.4 and see if it works there
>>> * if it does, I'll create TAG or branch to keep a stable version at that
>>> state
>>> * start looking into the issues of running it with postgis 2.x and pg9.2
>> Corrected!
>> A couple of points for anyone that wants to play with this. The first being
>> don't expect too much this is still a work in progress and has not been
>> tested.
>> git clone git at github.com:pgRouting/pgrouting.git
>> cd pgrouting
>> # Doh! I forgot this most important step ##############
>> git checkout sew-devel-2_0
>> # this requires cmake version 2.8.10
>> make
>> # assuming everything worked with out any issues you can see
>> # the install targets here
>> ls lib
>> librouting_dd.so  librouting_tsp.so     pgrouting--1.0.7.sql.in  README
>> librouting.so     pgrouting--1.0.7.sql  pgrouting.control
>> # make install will place *.so into pg_config --pkglibdir
>> # and *.{sql,control} will get placed in either:
>> # `pg_config --sharedir`/extension/  >= pg 9.1
>> # or /usr/share/pgrouting/            < pg 9.1
>> sudo make install
>> Have fun,
>>   -Steve
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Frédéric Bonifas
More information about the pgrouting-dev
