[pgrouting-dev] Problems linking on mingw64 between boost, cgal and threads
sanak geosanak at gmail.com
Wed Mar 20 17:11:59 PDT 2013
Hi Stephen,
Thanks for your improvement.
I will check it tonight.
Regards,
2013/3/21 Stephen Woodbridge <woodbri at swoodbridge.com>
> Hi sanak,
> I figured out a nice trick for scripting the bjam.exe bootstrap. You can
> change your instructions like this:
> Boost
>  Use old version(1.46.1) because of boost/graph/detail/is_same.hpp issue
>  $ cd /c/build
>  $ wget http://sourceforge.net/**projects/boost/files/boost/1.**
> 46.1/boost_1_46_1.zip<http://sourceforge.net/projects/boost/files/boost/1.46.1/boost_1_46_1.zip>
>  $ unzip boost_1_46_1.zip
>  $ cd boost_1_46_1/tools/build/v2
>  $ # the following will run the bootstrap.bat in cmd.exe and exit
>  $ cmd //c bootstrap.bat gcc
>  $ cp bjam.exe /c/build/boost_1_46_1/
>  $ cd /c/build/boost_1_46_1
>  $ bjam toolset=gcc address-model=32 define=BOOST_USE_WINDOWS_H
> link=static threading=multi --with-thread --prefix=/usr/local install
>  * Above bjam build instruction is quoted from the following site.
>    [Unable to build Boost libraries with GCC - Stack Overflow]
> http://stackoverflow.com/**questions/5299468/unable-to-**
> build-boost-libraries-with-gcc<http://stackoverflow.com/questions/5299468/unable-to-build-boost-libraries-with-gcc>
> Also for gaul I created a gaul.path file so instead of having the used
> edit the includes I run:
>  $ ./configure --enable-slang=no --enable-pthread=no --enable-shared=yes
>  $ cat /c/build/gaul.patch | patch -p1
> My patch file is:
> --- gaul-devel-0.1849-0/util/gaul/**gaul_config.h 2005-04-20 12:09:49
> -0400
> +++ gaul-devel-0.1849-0a/util/**gaul/gaul_config.h 2013-03-11 13:47:33
> -0400
> @@ -53,9 +53,9 @@
>  #ifdef WIN32
>  #  ifdef BUILDING_DLL
> -#    define FUNCPROTO __declspec (dllexport)
> +#    define FUNCPROTO
>  #  else
> -#    define FUNCPROTO __declspec (dllimport)
> +#    define FUNCPROTO
>  #  endif
>  #else
>  #  define FUNCPROTO
> --- gaul-devel-0.1849-0/util/gaul/**gaul_config_win.h     2005-04-14
> 11:08:56 -0400
> +++ gaul-devel-0.1849-0a/util/**gaul/gaul_config_win.h    2013-03-11
> 13:48:12 -0400
> @@ -39,9 +39,9 @@
>  #ifdef BUILDING_DLL
> +#  define FUNCPROTO
>  #else
> +#  define FUNCPROTO
>  #endif
>  #  if defined __CYGWIN32__ && !defined __CYGWIN__
> You might want to add these to your process.
> Thanks,
>   -Steve
> On 3/13/2013 10:44 AM, sanak wrote:
>> Hi Stephen,
>> I have updated the MinGW32/64 build instruction,
>> so, could you retry from boost build?
>> (Sorry, gcc PATH settings is not necessary, because msys.bat path
>> settings seems to be inherited by command prompt.)
>> https://github.com/sanak/**pgrouting4w/commit/**
>> e5ae697b3cb545b002702eda62c290**9382ae4521<https://github.com/sanak/pgrouting4w/commit/e5ae697b3cb545b002702eda62c2909382ae4521>
>> Regards,
>> 2013/3/13 sanak <geosanak at gmail.com <mailto:geosanak at gmail.com>>
>>     Hi Stephen,
>>     Oops, sorry, my boost_1_46_1/tools/build/bjam.**log shows "msvc10"
>>     which I have installed...
>>     I will check after returning from work. (about 12 hour later)
>>     Regards,
>>     2013/3/13 Stephen Woodbridge <woodbri at swoodbridge.com
>>     <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>
>>         OK, it looks like I have solved ISSUE 2, I think this was caused
>>         because I built boost with the 32 bit model in the 64 bit
>>         environment. I still can not not get ISSUE 1 to resolve and I
>>         had to rebuild it using the bjam I built under 1_51.
>>         To fix ISSUE to:
>>         1. rebuilt boost_1_46_1 as 64 bit model using bjam from 1_51
>>         2. rebuild CGAL
>>         3. rebuild pgrouting
>>         So I have at least on cuild of pgRouting
>>         So making progress in small steps :)
>>         If you have any additional thoughts on getting boost to build
>>         they would be appreciated.
>>         In my msys.bat shell, I have:
>>         PATH=/c/ming64/mingw64/bin/:/_**_home/woodbri/bin:.:/usr/**
>> local/__bin:/mingw/bin:/bin:/**c/oracle/__product/10.2.0/db_**
>> 1/bin:/c/__Windows/system32:/**c/Windows:/__c/Windows/**
>> System32/Wbem:/c/__Windows/**System32/__WindowsPowerShell/**
>> v1.0/:/c/__Program
>>         Files (x86)/QuickTime/QTSystem/
>>         Thanks,
>>            -Steve
>>         On 3/12/2013 11:34 AM, Stephen Woodbridge wrote:
>>             Hi Sanak,
>>             I'm still have an issue with this. Hopefully I followed your
>>             changes
>>             correctly:
>>             In my msys.bat shell I added the to the path:
>>             /c/ming64/mingw64/bin/, I
>>             have /c/ming64/ and /c/ming32/ trees setup so I can build on
>>             either.
>>             start cmd
>>             gcc -v               # is found and run
>>             bootstrap.bat gcc    # fails
>>             bootstrap.bat mingw  # fails
>>             exit
>>             $ cat tools/build/bjam.log
>>             ### Using 'msvc' toolset.
>>             c:\ming64\projects\boost_1_46_**
>> __1\tools\build\v2\engine\src>**if
>>             exist
>>             bootstrap rd /S /Q bootstrap
>> __1\tools\build\v2\engine\src>**md
>>             bootstrap
>> __1\tools\build\v2\engine\src>**cl
>>             /nologo /GZ
>>             /Zi /MLd /Fobootstrap/ /Fdbootstrap/ -DNT -DYYDEBUG
>> kernel32.lib
>>             advapi32.lib user32.lib /Febootstrap\jam0  command.c
>>             compile.c debug.c
>>             execnt.c expand.c filent.c glob.c hash.c hdrmacro.c
>>             headers.c jam.c
>>             jambase.c jamgram.c lists.c make.c make1.c newstr.c option.c
>>             output.c
>>             parse.c pathunix.c regexp.c rules.c scan.c search.c subst.c
>>             timestamp.c
>>             variable.c modules.c strings.c filesys.c builtins.c md5.c
>>             pwd.c class.c
>>             w32_getreg.c native.c modules/set.c modules/path.c
>>             modules/regex.c
>>             modules/property-set.c modules/sequence.c modules/order.c
>>             I looked at tools/build/v2/engine/src/__**build.bat but I'm
>>             not very
>>             familiar with windows bat files.
>>             -Steve
>>             On 3/12/2013 9:15 AM, sanak wrote:
>>                 Hi Stephen,
>>                 I updated MinGW32/64 build instruction to my "mingw"
>> branch,
>>                 and checked that MinGW64-bit build successed. (but not
>>                 tested)
>>                 https://github.com/sanak/__**pgrouting4w/commit/__**
>> 2a660524b53bcd80005e52917af5b3**__2b31749559<https://github.com/sanak/__pgrouting4w/commit/__2a660524b53bcd80005e52917af5b3__2b31749559>
>>                 <https://github.com/sanak/**pgrouting4w/commit/**
>> 2a660524b53bcd80005e52917af5b3**2b31749559<https://github.com/sanak/pgrouting4w/commit/2a660524b53bcd80005e52917af5b32b31749559>
>>                 so, retry from boost build about ISSUE1. (Thanks Pieter!)
>>                 Regards,
>>                 2013/3/12 Stephen Woodbridge <woodbri at swoodbridge.com
>>                 <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>
>>                 <mailto:woodbri at swoodbridge.__**com
>>                      Hi all,
>>                      I'm stuck at the moment trying to link the
>>                 pgrouting driving
>>                      directions module using mingw 64 bit. See the
>>                 issues below. So if
>>                      anyone has any thoughts on this it would be
>>                 appreciated. I will
>>                      check the current state of the files into my branch
>>                 in the morning
>>                      here (GMT-5) if you are setup to reproduce this. It
>>                 is too late to
>>                      do it with a clear head tonight. I'll also move it
>>                 back to Linux and
>>                      try again there as I have changed a lot of files.
>>                      Thanks,
>>                         -Steve
>>                      I have followed Sanak's directions from:
>>                 https://github.com/sanak/____**
>> pgrouting4w/blob/master/BUILD.**____mingw64<https://github.com/sanak/____pgrouting4w/blob/master/BUILD.____mingw64>
>>                 <https://github.com/sanak/__**
>> pgrouting4w/blob/master/BUILD.**__mingw64<https://github.com/sanak/__pgrouting4w/blob/master/BUILD.__mingw64>
>> pgrouting4w/blob/master/BUILD.**mingw64<https://github.com/sanak/pgrouting4w/blob/master/BUILD.mingw64>
>>                      ISSUE 1:
>>                      I first installed boost_1_51.zip but ran into
>>                 problems compiling so
>>                      installed boost_1_46_1.zip as he suggested. I was
>>                 able to bootstrap
>>                      1_51 and get a bjam.exe without a problem. But I
>>                 could not get
>>                      1_46_1 to bootstrap :(
>>                      Microsoft Windows [Version 6.1.7601]
>>                      Copyright (c) 2009 Microsoft Corporation.  All
>>                 rights reserved.
>>                      c:\ming64\projects\boost_1_46_**____1>bootstrap.bat
>> mingw
>>                      Building Boost.Jam build engine
>>                      'cl' is not recognized as an internal or external
>>                 command,
>>                      operable program or batch file.
>>                      Failed to build Boost.Jam build engine.
>>                      Please consult bjam.log for furter diagnostics.
>>                      You can try to obtain a prebuilt binary from
>>                 http://sf.net/project/____**
>> showfiles.php?group_id=7586&__**__package_id=72941<http://sf.net/project/____showfiles.php?group_id=7586&____package_id=72941>
>>                 <http://sf.net/project/__**showfiles.php?group_id=7586&__
>> **package_id=72941<http://sf.net/project/__showfiles.php?group_id=7586&__package_id=72941>
>>                 <http://sf.net/project/**showfiles.php?group_id=7586&**
>> package_id=72941<http://sf.net/project/showfiles.php?group_id=7586&package_id=72941>
>>                      Also, you can file an issue at http://svn.boost.org
>>                      Please attach bjam.log in that case.
>>                      So I built 1_46_1 using the bjam.exe that I built
>>                 in 1_51 and it
>>                      seems to have worked ok, but maybe that is part of
>>                 the problem.
>>                      ISSUE 2:
>>                      Is the follow mess from the linker
>>                      Scanning dependencies of target routing_dd
>>                      [ 80%] Building C object
>>                 core/driving_distance/src/____**
>> CMakeFiles/routing_dd.dir/____**alpha.c.obj
>>                      [ 86%] Building CXX object
>> CMakeFiles/routing_dd.dir/____**alpha_drivedist.cpp.obj
>>                      In file included from
>>                 c:/ming64/projects/pgx64/pg92/**
>> ____include/postgresql/server/**__pg___config_os.h:37:0,
>>                                        from
>> ____include/postgresql/server/**c.__h:__87,
>>                                        from
>> ____include/postgresql/server/**____postgres.h:47,
>>                                        from
>>                 c:/ming64/projects/pgrouting/_**
>> ___core/driving_distance/src/_**___alpha.h:27,
>>                                        from
>> ___core/driving_distance/src/_**___alpha_drivedist.cpp:46:
>>                 c:\ming64\mingw64\bin\../lib/_**
>> ___gcc/x86_64-w64-mingw32/4.5.**4/__.__./../../../x86_64-w64-_**
>> _mingw32/__include/winsock2.h:**__13:2:
>>                      warning: #warning Please include winsock2.h before
>>                 windows.h
>>                      [ 93%] Building CXX object
>> CMakeFiles/routing_dd.dir/____**boost_drivedist.cpp.obj
>>                      [100%] Building C object
>> CMakeFiles/routing_dd.dir/____**drivedist.c.obj
>>                      Linking CXX shared library
>>                 ../../../lib/librouting_dd.dll
>>                      Creating library file:
>>                 ../../../lib/librouting_dd.___**_dll.a
>>                 c:/ming64/msys/local/lib/____**
>> libboost_thread-mgw45-mt-1_46_**____1.a(thread.o):
>>                      duplicate section
>>                 `.data$_ZTVN5boost16exception_**
>> ____detail10clone_implINS0____**_19error_info_injectorISt9bad_**
>> ____allocEEEE[vtable
>>                      for
>>                 boost::exception_detail::____**
>> clone_impl<boost::exception___**__detail::error_info_injector<**
>> ____std::bad_alloc>
>>                       >]' has different size
>> libCGAL.a(all_files.cpp.obj):_**___all_files.cpp:(.text+**0xf898):
>>                      undefined reference to
>>                   `boost::system::generic_____**category()'
>> libCGAL.a(all_files.cpp.obj):_**___all_files.cpp:(.text+**0xf8a4):
>> libCGAL.a(all_files.cpp.obj):_**___all_files.cpp:(.text+**0xf8b0):
>>                 `boost::system::system_____**category()'
>>                      collect2: ld returned 1 exit status
>>                      make[2]: *** [lib/librouting_dd.dll] Error 1
>>                      make[1]: ***
>>                 [core/driving_distance/src/___**
>> _CMakeFiles/routing_dd.dir/**all]
>>                 Error 2
>>                      make: *** [all] Error 2
>>                      ______________________________**
>>                      pgrouting-dev mailing list
>>                 pgrouting-dev at lists.osgeo.org
>>                 <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>>                 <mailto:pgrouting-dev at lists.__**osgeo.org<http://osgeo.org>
>>                 http://lists.osgeo.org/____**
>> mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev><
>> http://lists.osgeo.org/__**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
>>                 <http://lists.osgeo.org/__**
>>                 <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>> **>__>
>>                 ______________________________**___________________
>>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130321/1523ba22/attachment-0001.html>
More information about the pgrouting-dev mailing list
