[pgrouting-dev] Bidirectional Integration bug
Stephen Woodbridge woodbri at swoodbridge.com
Tue May 7 09:34:04 PDT 2013
On 5/7/2013 1:35 AM, Razequl Islam wrote:
> Hi Steve,
> I also want to have a look at the possible problem. I am trying to set
> up the environment on my machine. I have the previous version. What do I
> need to do to get 2.0 working? Should I set up the environment from the
> scratch or should an update will do. Please let me know how I should
> proceed. I can also do the debugging once I have the environment in place.
If you have the old environment already there, then it should be as
simple as:
mkdir work
cd work
# if you already have a fork it might be better to work with that
git clone git://github.com/pgRouting/pgrouting.git
cd pgrouting
git checkout sew-devel-2_0
tools/doit
(cd build && sudo make install)
tools/test-runner.pl
tools/doit - a simple shell script to configure and compile. It creates
a directory "build" and all the build atrifacts go into it.
tools/test-runner.pl - is a perl script the runs the automated tests in
the database. If you have pg 9.1+ it assumes you can use "create
extension " for both postgis and pgrouting. If you have pg <9.1 then it
assumes you have already create a template_pgrouting database that has
postgis installed in it.
Currently, I have db_* test disabled as they crash. you can run them
manually with:
create a database with postgis and pgrouting installed in it say "test1"
# load the test data for dijkstra
psql -U postgres -h localhost -f
src/bd_dijkstra/test/bd_dijkstra-any-00.data test1
# run a test(s) for dijkstra (test are 01-06)
src/bd_dijkstra/test/bd_dijkstra-any-01.test test1
# load the test data for astar
psql -U postgres -h localhost -f src/bd_astar/test/bd_astar-any-00.data
test1
# run a test(s) for astar(test are 01-06)
psql -U postgres -h localhost -f src/bd_astar/test/bd_astar-any-01.test
test1
I have run both your unit test files in "tester" directory and they run
ok, So it has something to do with the integration.
Thanks,
   -Steve
> Thanks.
> - Razequl
> On Mon, May 6, 2013 at 11:32 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Hi Razequl,
>     I have been trying to integrate your bidirectional shortest path
>     code. I have merged the code into my pgrouting branch
>     "sew-devel-2_0", but it is crashing the back-end with a segv.
>     If you have time and want to look into this that would be great as I
>     would like to get this code working in 2.0.
>     I'm not sure if I found a bug in your code or I broke something when
>     I merged it, or for that matter that I even merged the correct code
>     :) because you sent email indicating that you fixed stuff. I merged
>     the code from master at https://github.com/zibon/__pgrouting
>     <https://github.com/zibon/pgrouting>
>     I also ran into an issue that when I merged you code into the code
>     library, that the trsp broke, then take you code out and it works
>     again. I assume that there is some kind of function name or global
>     initialization issue. This does not seem to be an issue for trsp now
>     that the bi-dir code is in a separate library.
>     This might give you a chance to get your development/test/debug
>     environment setup and to familiarize yourself with the new source
>     code layout.
>     Let me know if you have time and I'll help point the way. If you are
>     tied up with class work, etc that clearly takes priority.
>     Thanks,
>        -Steve
More information about the pgrouting-dev mailing list
