[pgrouting-dev] pgRouting 2.0 using OSX homebrew
Stephen Woodbridge woodbri at swoodbridge.com
Tue May 7 13:11:58 PDT 2013
On 5/7/2013 10:27 AM, Alec Gosse wrote:
> Hello all,
> I am working on a bicycle routing project and converting from Open
> Trip Planner to pgRouting on both OSX and 64bit Ubuntu with
> PostgreSQL 9.1+. For me, the sew-revel-2_0 branch will build under
> ubuntu 12.10, but not on OSX 10.8 using dependencies installed
> through Homebrew.
> Homebrew is certainly the best way I've found to install open-source
> tools on a mac, so I would like to help get pgRouting 2.0 installable
> that way. Homebrew tends to use quite current packages such as boost
> 1.53, however, but I see in tool/NOTES.txt that pgRouting requires
> boost 1.46.1? Since things build on Ubuntu using boost 1.49, I'm
> wondering if this still applies?
Well the required version is whatever you can get to work. I know there
are some problems with 1.47, but those might be specific to that version.
> In either case, what's the best way for me to help get things running
> under OSX? Should I post errors I can't resolve to the list, and or
> is someone already working on this?
Yes, We can try to help if we know what errors you are seeing. I'm not
sure anyone here has OSX so you might need to take some initiative to
figure things out. If you look at the CMakeLists.txt files that are
sprinkled throughout the project tree, you will see that some of them
have blocks like:
if(APPLE)
endif(APPLE)
maybe we don't have these setup correctly or maybe some are missing that
need to be added. It would be great if you can help with this.
Thanks,
   -Steve
> Best, Conrad (Alec) Gosse, MUEP Doctoral Candidate: Civil &
> Environmental Engineering University of Virginia Charlottesville, VA
> On May 7, 2013, at 1:40 AM, Daniel Kastl <daniel at georepublic.de>
> wrote:
>> Hi Razequl,
>> The currently used branch is named "sew-devel-2_0" (we're planning
>> to rename it to "develop" some time). You find all the necessary
>> steps to compile explained on the Github readme:
>> https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0
>> If you want to compile with support for "Driving Distance", then
>> you need to have CGAL libraries as dependency. GAUL dependency is
>> gone.
>> Daniel
>> On Tue, May 7, 2013 at 2:35 PM, Razequl Islam
>> <ziboncsedu at gmail.com> wrote: Hi Steve, I also want to have a look
>> at the possible problem. I am trying to set up the environment on
>> my machine. I have the previous version. What do I need to do to
>> get 2.0 working? Should I set up the environment from the scratch
>> or should an update will do. Please let me know how I should
>> proceed. I can also do the debugging once I have the environment in
>> place.
>> Thanks. - Razequl
>> On Mon, May 6, 2013 at 11:32 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com> wrote: Hi Razequl,
>> I have been trying to integrate your bidirectional shortest path
>> code. I have merged the code into my pgrouting branch
>> "sew-devel-2_0", but it is crashing the back-end with a segv.
>> If you have time and want to look into this that would be great as
>> I would like to get this code working in 2.0.
>> I'm not sure if I found a bug in your code or I broke something
>> when I merged it, or for that matter that I even merged the correct
>> code :) because you sent email indicating that you fixed stuff. I
>> merged the code from master at https://github.com/zibon/pgrouting
>> I also ran into an issue that when I merged you code into the code
>> library, that the trsp broke, then take you code out and it works
>> again. I assume that there is some kind of function name or global
>> initialization issue. This does not seem to be an issue for trsp
>> now that the bi-dir code is in a separate library.
>> This might give you a chance to get your development/test/debug
>> environment setup and to familiarize yourself with the new source
>> code layout.
>> Let me know if you have time and I'll help point the way. If you
>> are tied up with class work, etc that clearly takes priority.
>> Thanks, -Steve
>> _______________________________________________ pgrouting-dev
>> mailing list pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> -- Georepublic UG & Georepublic Japan eMail:
>> daniel.kastl at georepublic.de Web: http://georepublic.de
> _______________________________________________ pgrouting-dev mailing
More information about the pgrouting-dev mailing list
