[pgrouting-dev] pgRouting 2.0 using OSX homebrew
Stephen Woodbridge woodbri at swoodbridge.com
Wed May 8 08:55:22 PDT 2013
Hi sanak,
I looked at your changes below, and they do not seem to be based on my
branch "sew-devel-2_0". The quick tell is that my source starts at
"src/" and not "core/" as your changes reflect.
For linux I compile, install and test using:
tools/doit
(cd build; sudo make install)
tools/testrunner.pl
In the C/C++ code you should be able to use:
#ifdef __APPLE__
#else
#endif
and in cmake you can use:
if(APPLE)
else(APPLE)
endif(APPLE)
Can you also post what the results of:
echo | g++ -dM -E -
when run on OSX.
No hurray, when you can get to it, this weekend is fine.
Thanks,
   -Steve
On 5/7/2013 6:05 PM, sanak wrote:
> Hi Alec, Stephen,
> About 1 month ago, I tried Mac ports build in my private
> branch("macports") which is based on "sew-revel-2_0",
> and confirmed that it can build with Mac OSX 10.8(Mountain Lion).
> https://github.com/sanak/pgrouting4w/commit/7291a7b6be3bd37c9e507048bfe3ba0fcf0c5c6e
> Now, I am busy for other task, but, I will check and test it in this
> weekend.
> 2013/5/8 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>
>     On 5/7/2013 10:27 AM, Alec Gosse wrote:
>         Hello all,
>         I am working on a bicycle routing project and converting from Open
>         Trip Planner to pgRouting on both OSX and 64bit Ubuntu with
>         PostgreSQL 9.1+. For me, the sew-revel-2_0 branch will build under
>         ubuntu 12.10, but not on OSX 10.8 using dependencies installed
>         through Homebrew.
>         Homebrew is certainly the best way I've found to install open-source
>         tools on a mac, so I would like to help get pgRouting 2.0
>         installable
>         that way. Homebrew tends to use quite current packages such as boost
>         1.53, however, but I see in tool/NOTES.txt that pgRouting requires
>         boost 1.46.1? Since things build on Ubuntu using boost 1.49, I'm
>         wondering if this still applies?
>     Well the required version is whatever you can get to work. I know
>     there are some problems with 1.47, but those might be specific to
>     that version.
>         In either case, what's the best way for me to help get things
>         running
>         under OSX? Should I post errors I can't resolve to the list, and or
>         is someone already working on this?
>     Yes, We can try to help if we know what errors you are seeing. I'm
>     not sure anyone here has OSX so you might need to take some
>     initiative to figure things out. If you look at the CMakeLists.txt
>     files that are sprinkled throughout the project tree, you will see
>     that some of them have blocks like:
>     if(APPLE)
>     endif(APPLE)
>     maybe we don't have these setup correctly or maybe some are missing
>     that need to be added. It would be great if you can help with this.
>     Thanks,
>        -Steve
>         Best, Conrad (Alec) Gosse, MUEP Doctoral Candidate: Civil &
>         Environmental Engineering University of Virginia Charlottesville, VA
>         On May 7, 2013, at 1:40 AM, Daniel Kastl <daniel at georepublic.de
>         <mailto:daniel at georepublic.de>>
>         wrote:
>             Hi Razequl,
>             The currently used branch is named "sew-devel-2_0" (we're
>             planning
>             to rename it to "develop" some time). You find all the necessary
>             steps to compile explained on the Github readme:
>             https://github.com/pgrouting/__pgrouting/tree/sew-devel-2_0
>             <https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0>
>             If you want to compile with support for "Driving Distance", then
>             you need to have CGAL libraries as dependency. GAUL
>             dependency is
>             gone.
>             Daniel
>             On Tue, May 7, 2013 at 2:35 PM, Razequl Islam
>             <ziboncsedu at gmail.com <mailto:ziboncsedu at gmail.com>> wrote:
>             Hi Steve, I also want to have a look
>             at the possible problem. I am trying to set up the
>             environment on
>             my machine. I have the previous version. What do I need to do to
>             get 2.0 working? Should I set up the environment from the
>             scratch
>             or should an update will do. Please let me know how I should
>             proceed. I can also do the debugging once I have the
>             environment in
>             place.
>             Thanks. - Razequl
>             On Mon, May 6, 2013 at 11:32 PM, Stephen Woodbridge
>             <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>
>             wrote: Hi Razequl,
>             I have been trying to integrate your bidirectional shortest path
>             code. I have merged the code into my pgrouting branch
>             "sew-devel-2_0", but it is crashing the back-end with a segv.
>             If you have time and want to look into this that would be
>             great as
>             I would like to get this code working in 2.0.
>             I'm not sure if I found a bug in your code or I broke something
>             when I merged it, or for that matter that I even merged the
>             correct
>             code :) because you sent email indicating that you fixed
>             stuff. I
>             merged the code from master at
>             https://github.com/zibon/__pgrouting
>             <https://github.com/zibon/pgrouting>
>             I also ran into an issue that when I merged you code into
>             the code
>             library, that the trsp broke, then take you code out and it
>             works
>             again. I assume that there is some kind of function name or
>             global
>             initialization issue. This does not seem to be an issue for trsp
>             now that the bi-dir code is in a separate library.
>             This might give you a chance to get your development/test/debug
>             environment setup and to familiarize yourself with the new
>             source
>             code layout.
>             Let me know if you have time and I'll help point the way. If you
>             are tied up with class work, etc that clearly takes priority.
>             Thanks, -Steve
>             _________________________________________________ pgrouting-dev
>             mailing list pgrouting-dev at lists.osgeo.org
>             <mailto:pgrouting-dev at lists.osgeo.org>
>             http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
>             <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>             -- Georepublic UG & Georepublic Japan eMail:
>             daniel.kastl at georepublic.de
>             <mailto:daniel.kastl at georepublic.de> Web: http://georepublic.de
>         mailing
>     pgrouting-dev mailing list
>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
More information about the pgrouting-dev mailing list
