[pgrouting-dev] pgRouting 2.0 using OSX homebrew
    Daniel Kastl
    daniel at georepublic.de
    Wed May  8 10:15:37 PDT 2013
>  How do I go about contributing these edits once I get it all
>> working?
> Best way, is to fork the pgrouting respository, make your changes there
> and issue a pull request so we can merge your changes.
For sure this would be easiest and best solution.
> If there are not too many changes, you could do something like:
> git diff > mychanges-diff.txt
> And open a ticket and attache the diff file to the ticket.
I think Github doesn't  allow to attach files to tickets (just looked for
it last week), but an alternative would be to use Gist:
https://gist.github.com/
Nevertheless, to fork the repository and then submit a pull request would
be better:
https://help.github.com/articles/using-pull-requests
Daniel
> -Steve
>  Best, Alec
>> On May 8, 2013, at 11:55 AM, Stephen Woodbridge
>> <woodbri at swoodbridge.com> wrote:
>>  Hi sanak,
>>> I looked at your changes below, and they do not seem to be based on
>>> my branch "sew-devel-2_0". The quick tell is that my source starts
>>> at "src/" and not "core/" as your changes reflect.
>>> For linux I compile, install and test using:
>>> tools/doit (cd build; sudo make install) tools/testrunner.pl
>>> In the C/C++ code you should be able to use:
>>> #ifdef __APPLE__ ... #else ... #endif
>>> and in cmake you can use:
>>> if(APPLE) ... else(APPLE) ... endif(APPLE)
>>> Can you also post what the results of:
>>> echo | g++ -dM -E -
>>> when run on OSX.
>>> No hurray, when you can get to it, this weekend is fine.
>>> Thanks, -Steve
>>> On 5/7/2013 6:05 PM, sanak wrote:
>>>> Hi Alec, Stephen,
>>>> About 1 month ago, I tried Mac ports build in my private
>>>> branch("macports") which is based on "sew-revel-2_0", and
>>>> confirmed that it can build with Mac OSX 10.8(Mountain Lion).
>>>> https://github.com/sanak/**pgrouting4w/commit/**
>>>> 7291a7b6be3bd37c9e507048bfe3ba**0fcf0c5c6e<https://github.com/sanak/pgrouting4w/commit/7291a7b6be3bd37c9e507048bfe3ba0fcf0c5c6e>
>>>>  Now, I am busy for other task, but, I will check and test it in this
>>  weekend.
>>>> 2013/5/8 Stephen Woodbridge <woodbri at swoodbridge.com
>>>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>
>>>> On 5/7/2013 10:27 AM, Alec Gosse wrote:
>>>> Hello all,
>>>> I am working on a bicycle routing project and converting from
>>>> Open Trip Planner to pgRouting on both OSX and 64bit Ubuntu with
>>>> PostgreSQL 9.1+. For me, the sew-revel-2_0 branch will build
>>>> under ubuntu 12.10, but not on OSX 10.8 using dependencies
>>>> installed through Homebrew.
>>>> Homebrew is certainly the best way I've found to install
>>>> open-source tools on a mac, so I would like to help get pgRouting
>>>> 2.0 installable that way. Homebrew tends to use quite current
>>>> packages such as boost 1.53, however, but I see in tool/NOTES.txt
>>>> that pgRouting requires boost 1.46.1? Since things build on
>>>> Ubuntu using boost 1.49, I'm wondering if this still applies?
>>>> Well the required version is whatever you can get to work. I
>>>> know there are some problems with 1.47, but those might be
>>>> specific to that version.
>>>> In either case, what's the best way for me to help get things
>>>> running under OSX? Should I post errors I can't resolve to the
>>>> list, and or is someone already working on this?
>>>> Yes, We can try to help if we know what errors you are seeing.
>>>> I'm not sure anyone here has OSX so you might need to take some
>>>> initiative to figure things out. If you look at the
>>>> CMakeLists.txt files that are sprinkled throughout the project
>>>> tree, you will see that some of them have blocks like:
>>>> if(APPLE) ... endif(APPLE)
>>>> maybe we don't have these setup correctly or maybe some are
>>>> missing that need to be added. It would be great if you can help
>>>> with this.
>>>> Thanks, -Steve
>>>> Best, Conrad (Alec) Gosse, MUEP Doctoral Candidate: Civil &
>>>> Environmental Engineering University of Virginia Charlottesville,
>>>> VA
>>>> On May 7, 2013, at 1:40 AM, Daniel Kastl <daniel at georepublic.de
>>>> <mailto:daniel at georepublic.de>**> wrote:
>>>> Hi Razequl,
>>>> The currently used branch is named "sew-devel-2_0" (we're
>>>> planning to rename it to "develop" some time). You find all the
>>>> necessary steps to compile explained on the Github readme:
>>>> https://github.com/pgrouting/_**_pgrouting/tree/sew-devel-2_0<https://github.com/pgrouting/__pgrouting/tree/sew-devel-2_0>
>>>> <https://github.com/pgrouting/**pgrouting/tree/sew-devel-2_0<https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0>
>>>> If you want to compile with support for "Driving Distance", then
>>>> you need to have CGAL libraries as dependency. GAUL dependency
>>>> is gone.
>>>> Daniel
>>>> On Tue, May 7, 2013 at 2:35 PM, Razequl Islam
>>>> <ziboncsedu at gmail.com <mailto:ziboncsedu at gmail.com>> wrote: Hi
>>>> Steve, I also want to have a look at the possible problem. I am
>>>> trying to set up the environment on my machine. I have the
>>>> previous version. What do I need to do to get 2.0 working? Should
>>>> I set up the environment from the scratch or should an update
>>>> will do. Please let me know how I should proceed. I can also do
>>>> the debugging once I have the environment in place.
>>>> Thanks. - Razequl
>>>> On Mon, May 6, 2013 at 11:32 PM, Stephen Woodbridge
>>>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>>>> wrote:
>>>> Hi Razequl,
>>>> I have been trying to integrate your bidirectional shortest path
>>>> code. I have merged the code into my pgrouting branch
>>>> "sew-devel-2_0", but it is crashing the back-end with a segv.
>>>> If you have time and want to look into this that would be great
>>>> as I would like to get this code working in 2.0.
>>>> I'm not sure if I found a bug in your code or I broke something
>>>> when I merged it, or for that matter that I even merged the
>>>> correct code :) because you sent email indicating that you fixed
>>>> stuff. I merged the code from master at
>>>> https://github.com/zibon/__**pgrouting<https://github.com/zibon/__pgrouting>
>>>> <https://github.com/zibon/**pgrouting<https://github.com/zibon/pgrouting>
>>>> I also ran into an issue that when I merged you code into the
>>>> code library, that the trsp broke, then take you code out and it
>>>> works again. I assume that there is some kind of function name
>>>> or global initialization issue. This does not seem to be an issue
>>>> for trsp now that the bi-dir code is in a separate library.
>>>> This might give you a chance to get your development/test/debug
>>>> environment setup and to familiarize yourself with the new
>>>> source code layout.
>>>> Let me know if you have time and I'll help point the way. If you
>>>> are tied up with class work, etc that clearly takes priority.
>>>> Thanks, -Steve
>>>> ______________________________**___________________ pgrouting-dev
>>>> mailing list pgrouting-dev at lists.osgeo.org
>>>> <mailto:pgrouting-dev at lists.**osgeo.org <pgrouting-dev at lists.osgeo.org>
>>>> http://lists.osgeo.org/__**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>
>>>> <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>>> -- Georepublic UG & Georepublic Japan eMail:
>>>> daniel.kastl at georepublic.de <mailto:daniel.kastl@**georepublic.de<daniel.kastl at georepublic.de>
>>>> Web: http://georepublic.de
>>>> ______________________________**_________________ pgrouting-dev
>> ______________________________**_________________ pgrouting-dev mailing
> pgrouting-dev mailing list
eMail: daniel.kastl at georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130509/d015d7b3/attachment.html>
More information about the pgrouting-dev
