[pgrouting-dev] pgRouting 2.0
Daniel Kastl daniel at georepublic.de
Fri May 10 07:31:29 PDT 2013
On Fri, May 10, 2013 at 11:01 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> On 5/10/2013 9:44 AM, Stephen Mather wrote:
>> Hi All,
>> In looking at the 2.0 branch on GitHub
>> <https://github.com/pgRouting/**pgrouting/tree/sew-devel-2_0<https://github.com/pgRouting/pgrouting/tree/sew-devel-2_0>>,
>> the
>> documentation to prep for install points to
>> http://pgrouting.org/docs/1.x/**install.html<http://pgrouting.org/docs/1.x/install.html>but does not indicate the
>> GAUL is no longer a dependency.  GAUL is no longer a dependency, correct?
> Correct, GAUL, it not a dependency on 2.0, I'll open a ticket to clean up
> the doc.
The link to the docs in the Readme goes to the website and of course the
website is for the current version.
I would just remove the two links at the beginning of Readme.md and write
the requirements directly into the file.
Daniel
> Thanks,
>   -Steve
> ______________________________**_________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130510/741063be/attachment.html>
More information about the pgrouting-dev mailing list
