[pgrouting-dev] memory usage in bulk routing
Stephen Woodbridge woodbri at swoodbridge.com
Fri May 10 10:20:41 PDT 2013
On 5/10/2013 12:34 PM, Alec Gosse wrote:
> Hello, and please let me know if this off topic for this list.
> My application processes a large number of routes (~500k) in a batch.
> Each routing task is independent, however even processing ~100
> requires multiple GB of ram on a graph of 50k edges. Memory usage
> grows continually as the query is running rather than leveling out as
> I would expect, which makes me think that each routing task is
> holding onto its memory until they all finish. I tried breaking the
> query into small chunks within a plpgsql loop, but to no benefit.
> Is this an accurate assessment, and or, is there a feasible way to
> route many trips in bulk from a table of start and end points?
Alec,
What routing algorithm (function) are you using?
This sounds like there might be a memory leak. The other possibility is
that this is all getting done in a single transaction and I have run
into issues because of this. For example, I had a process that I wrapped
into a stored procedure to iterate through a table, run a query and
update a table and that soaked up huge amounts of memory, but when I
rewrote it in perl as a client side script that did a query of a table
and then issued a new queries for each table row it did not use a lot of
memory. My understanding is that everything done in a stored procedure
is done implicitly in a transaction. So the perl script was done in a
transaction.
If you are interested in coding some C/C++, one idea that I had is to
create a function that takes a list of locations, builds a single graph
then computes the distances for all pair combinations in the list.
Another variant of this would be to pass it a list of location pairs,
and it could return a tout for each pair.
A large part of the cost is in building the graph, so if you can do it
once and reuse it, then you get a huge benefit. I have not had time of
funding to build something like this but it would be a great feautre to
add to pgrouting. What is your use case for?
-Steve
More information about the pgrouting-dev mailing list
