[pgrouting-dev] pgRouting 2.0 using OSX homebrew
sanak geosanak at gmail.com
Fri May 10 21:33:54 PDT 2013
Hi Alec, Stephen,
I confirmed that MacOSX MacPorts build successfully with current
"sew-devel-2_0" branch,
and all tests passed by "tools/test-runner.pl".
Thanks for your great jobs!
2013/5/9 sanak <geosanak at gmail.com>
> Hi Alec,
> Thanks for your pull request!
> 2013/5/9 Alec Gosse <alec at thegosses.com>
>> Thank you all for your guidance. I've submitted a pull request for my
>> changes. As I noted in the text of the request, librouting_tsp and
>> librouting_ksp are being built as static rather than dynamic libraries, so
>> make install fails since they have the extension .a rather than .so. Any
>> thoughts on this would be most appreciated.
>> The only other trouble I've run across is a very long list of warnings
>> like this while compiling:
>> /usr/local/src/pgrouting/src/driving_distance/src/drivedist.c:220:34:
>> warning: use of GNU old-style field designator extension [-Wgnu-designator]
>>   edge_columns_t edge_columns = {id: -1, source: -1, target: -1,
> I guess that above warning cause is Clang(LLVM)'s g++ compatibility,
> so, more custom CMake settings may be necessary.
> I will check about it in this weekend (or later).
> Thanks,
> Sanak
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130511/cde51645/attachment-0001.html>
More information about the pgrouting-dev mailing list
