[pgrouting-dev] How many people use the wrapper functions?
Stephen Woodbridge woodbri at swoodbridge.com
Sun May 12 06:41:26 PDT 2013
Worth,
Thanks, this is good to know and validates our thoughts on the need for
a chapter in the doc on how to write wrapper functions.
I write a lot code in plpgsql for the same reasons. It also tends to be
much faster to process stuff in the database. I write trivial 10-20
lines PHP scripts the do nothing more than:
1. take user input
2. connect to the database
3. issue a query to a stored procedure
4. format the results as XML or JSON
to then access these functions from web clients and other client scripts
and programs.
We actually will be adding some new plpgsql function as part of 2.0 for
example you might find these interesting:
pgr_analyzeGraph    - analyze a topology and mark dead ends
pgr_analyzeOneway   - analyze a topology and look for impossible oneways
pgr_nodeNetwork     - utility that will node all intersections
Those can be useful determining issues with a road network that might
cause problems when routing and nodeNetwork is a tool to potentally
solve one class of problem where the road segments are not split at
intersections.
pgr_isColumnInTable - utility to see if a column exists in a table
pgr_isColumnIndexed - utility to see if a column is indexed
And I'm sure there will be a few others as the release progresses.
Thanks,
   -Steve
On 5/12/2013 7:52 AM, Worth Lutz wrote:
> Steve,
> Thanks for the suggestion on TSRP. I'll look at it as soon as I finish my
> current project.
> I'll like to add that I learned to write PL/pgSQl from reading the pgRouting
> wrappers. I usually write in PHP but find that moving stuff to SQL and
> PL/pgSQl can simplify my application. At least once I figure out the
> intricacies of the particular query.
> Having the wrapper examples is helpful to someone learning. I found that you
> have to figure out how they work though because as you pointed out there
> were problems and hard-coded stuff which may cause problems.  I had a type
> problem when I was figuring out my application.
> Simple wrappers as examples to explain to someone how to set up their own
> wrapper are helpful.
> Worth
> -----Original Message-----
> From: pgrouting-dev-bounces at lists.osgeo.org
> [mailto:pgrouting-dev-bounces at lists.osgeo.org] On Behalf Of Stephen
> Woodbridge
> Sent: Saturday, May 11, 2013 10:00 PM
> To: pgRouting developers mailing list
> Subject: Re: [pgrouting-dev] How many people use the wrapper functions?
> Hi Worth,
> Thank you for the feedback. It is really important the people speak up
> on this because our current thinking is that we will probably take most
> of the wrapper functions and dump them into a depreciated
> pgrouting-legacy.sql file that will get copied to the server, but not
> installed when you CREATE EXTENSION pgrouting;
> I have talked with Daniel about improving the documentation and may be
> adding a chapter that explains how to write your own wrapper function.
> Our thought is that if we had fewer functions that were better
> documented that it would be easier for people to make sense of how to
> use from the beginning.
> Regarding shooting star, you should just start using TRSP. In fact it
> has the ability to specify an edge and a percentage along the edge for
> the start and end locations. It also about 5 times faster than shooting
> start.
> With regards to the parallel edge problem. We have this in dijkstra and
> astar and it is on my list of things to fix before the release. I am not
> sure if trsp has this or not, but if you can make a test for it I would
> be interested in the results.
> Thanks,
>     -Steve
> On 5/11/2013 7:51 PM, Worth Lutz wrote:
>> Hi Steve,
>> I used one of the wrappers, shootingstar_sp_smart I think, but had to
> modify
>> it due to problems. I think that it is the one which uses shooting star
>> which I've since heard doesn't work.
>> I think that it works for us as all we are using is length as cost to find
>> the length from a to b. No turn restrictions or anything.
>> I chose it because the wrapper let me choose a point and it split the
>> nearest edge and hooked up the point to that edge at the split.
>> Another reason I chose it was that it worked for the following situation:
>> A -----/               B
>> |_____________________/
>> Other algorithms would choose the upper edge because that is what was
> found
>> first as they tried to go from A to B. I was just learning about routing
> and
>> did not want to go figure out how to modify my network to split the long
>> path where there were multiple paths between nodes.
>> I've been following your work lately as I will be upgrading our situation
> to
>> Postgres 9 and PostGIS 2 at some point. I was waiting for you to get
> things
>> settled out before asking which algorithm I should look at to replace
>> shootingstar.
>> Thanks for your work on this project.
>> Worth Lutz
>> Woodbridge
>> Sent: Saturday, May 11, 2013 4:21 PM
>> To: pgRouting Users List; pgRouting Dev List
>> Subject: [pgrouting-dev] How many people use the wrapper functions?
>> Hi all,
>> Daniel and I have been wondering if people use the wrapper function
>> versus the core functions directly? Or if you have written your own
>> wrapper functions? etc.
>> The core functions are the low level function that directly call the
>> internal library functions.
>> The wrapper functions are all the additional plpgsql convenience
>> functions that generate more complex SQL queries and then call the core
>> functions.
>> I know that I never use the wrapper functions because I found them to
>> messy and inconsistent and have hard coded values in them, etc. So I
>> wrote my own high level wrapper functions that made it easy for me to
>> work with the core functions.
>> So I thought it would be wise to ask our users what they use? and how
>> they use pgRouting, so we do not may a decision like "Throw out the
>> wrapper functions" without some input from the user community.
>> PLEASE TAKE ACTION and let us know!
>> Thanks,
>>      -Steve
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> No virus found in this message.
>> Checked by AVG - www.avg.com
>> Version: 2013.0.3336 / Virus Database: 3162/6317 - Release Date: 05/11/13
More information about the pgrouting-dev mailing list
