[pgrouting-dev] OSX build error
Stephen Woodbridge woodbri at swoodbridge.com
Tue May 28 13:15:19 PDT 2013
I made these changes and they compile and work in linux, so I just
pushed them. do another pull and try again.
Let me know how that goes,
   -Steve
On 5/28/2013 4:11 PM, Stephen Woodbridge wrote:
> Actually, it looks like there are two occurances that need to be changed.
> -Steve
> On 5/28/2013 4:07 PM, Stephen Woodbridge wrote:
>> On 5/28/2013 3:51 PM, Alec Gosse wrote:
>>> Hello,
>>> I just pulled the latest in the sew_devel_2-0 branch and got the
>>> following compiler error under Mac 10.8.
>>> /usr/local/src/pgrouting_main/src/kdijkstra/src/k_targets_boost_wrapper.cpp:341:26:
>>> error: variable length array of non-POD element type
>>>        'vector<int>'
>>>      vector<int> path_vect[nb_targets];
>>> I can confirm that this does not occur on my Ubuntu machine.
>> Hi Alec,
>> I'm not very good with C++, but as a guess, can you edit that line 341
>> and change it from:
>> to:
>> std::vector<int> path_vect[nb_targets];
>> And let me know if that fixes your compile problem.
>> Thanks,
>>    -Steve
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
