[pgrouting-dev] OSX build error
Stephen Woodbridge woodbri at swoodbridge.com
Tue May 28 16:38:39 PDT 2013
OK, I did more research and I might have a fix for this. I just pushed
some updated code. Let me know how that works out.
-Steve
On 5/28/2013 5:17 PM, Stephen Woodbridge wrote:
> On 5/28/2013 4:38 PM, Alec Gosse wrote:
>> Sorry, that did not fix the issue:
>> /usr/local/src/pgrouting_main/src/kdijkstra/src/k_targets_boost_wrapper.cpp:341:31:
>> error: variable length array of non-POD element type
>>        'std::vector<int>'
>>      std::vector<int> path_vect[nb_targets];
> What happens if you change this from:
> to:
> std::vector<int> path_vect(nb_targets);
> I just guessing here, so someone with C++ experience please jump in!
> -Steve
>> This link:
>> http://stackoverflow.com/questions/9550712/variable-length-array-of-non-pod-element-type-string-aka-basic-stringchar
>> suggests that the code relies on a g++ extension of the language
>> standard?
>> Alec
>> On May 28, 2013, at 4:15 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com> wrote:
>>> I made these changes and they compile and work in linux, so I just
>>> pushed them. do another pull and try again.
>>> Let me know how that goes,
>>>   -Steve
>>> On 5/28/2013 4:11 PM, Stephen Woodbridge wrote:
>>>> Actually, it looks like there are two occurances that need to be
>>>> changed.
>>>> -Steve
>>>> On 5/28/2013 4:07 PM, Stephen Woodbridge wrote:
>>>>> On 5/28/2013 3:51 PM, Alec Gosse wrote:
>>>>>> Hello,
>>>>>> I just pulled the latest in the sew_devel_2-0 branch and got the
>>>>>> following compiler error under Mac 10.8.
>>>>>> /usr/local/src/pgrouting_main/src/kdijkstra/src/k_targets_boost_wrapper.cpp:341:26:
>>>>>>        'vector<int>'
>>>>>> I can confirm that this does not occur on my Ubuntu machine.
>>>>> Hi Alec,
>>>>> I'm not very good with C++, but as a guess, can you edit that line 341
>>>>> and change it from:
>>>>> to:
>>>>> And let me know if that fixes your compile problem.
>>>>> Thanks,
>>>>>    -Steve
>>>>> _______________________________________________
>>>>> pgrouting-dev mailing list
>>>>> pgrouting-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
