[pgrouting-dev] OSX build error
Stephen Woodbridge woodbri at swoodbridge.com
Tue May 28 20:31:26 PDT 2013
Duh! I must have missed that one. That is a know issue and I thought I
caught all of them, but I guess not. Fix just pushed, please try again.
Thank you for the reports and your patience.
-Steve
On 5/28/2013 9:59 PM, Alec Gosse wrote:
> Here's the new compile result:
> /usr/local/include/boost/graph/detail/adjacency_list.hpp:2655:27: error: cannot form a reference to 'void'
>          typedef value_type& reference;
> /usr/local/include/boost/graph/detail/adjacency_list.hpp:2656:33: error: cannot form a reference to 'void'
>          typedef const value_type& const_reference;
> /usr/local/src/pgrouting_main/src/kdijkstra/src/k_targets_boost_wrapper.cpp:285:48: error: use of undeclared identifier 'weightmap'; did you mean
>        'weight_map'?
>      property_map<graph_t, edge_weight_t>::type weightmap = get(edge_weight, graph);
>                                                 weight_map
> Alec
> On May 28, 2013, at 7:38 PM, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>> OK, I did more research and I might have a fix for this. I just pushed some updated code. Let me know how that works out.
>> -Steve
>> On 5/28/2013 5:17 PM, Stephen Woodbridge wrote:
>>> On 5/28/2013 4:38 PM, Alec Gosse wrote:
>>>> Sorry, that did not fix the issue:
>>>> /usr/local/src/pgrouting_main/src/kdijkstra/src/k_targets_boost_wrapper.cpp:341:31:
>>>> error: variable length array of non-POD element type
>>>>        'std::vector<int>'
>>>>      std::vector<int> path_vect[nb_targets];
>>> What happens if you change this from:
>>> to:
>>> std::vector<int> path_vect(nb_targets);
>>> I just guessing here, so someone with C++ experience please jump in!
>>> -Steve
>>>> This link:
>>>> http://stackoverflow.com/questions/9550712/variable-length-array-of-non-pod-element-type-string-aka-basic-stringchar
>>>> suggests that the code relies on a g++ extension of the language
>>>> standard?
>>>> Alec
>>>> On May 28, 2013, at 4:15 PM, Stephen Woodbridge
>>>>> I made these changes and they compile and work in linux, so I just
>>>>> pushed them. do another pull and try again.
>>>>> Let me know how that goes,
>>>>>   -Steve
>>>>> On 5/28/2013 4:11 PM, Stephen Woodbridge wrote:
>>>>>> Actually, it looks like there are two occurances that need to be
>>>>>> changed.
>>>>>> -Steve
>>>>>> On 5/28/2013 4:07 PM, Stephen Woodbridge wrote:
>>>>>>> On 5/28/2013 3:51 PM, Alec Gosse wrote:
>>>>>>>> Hello,
>>>>>>>> I just pulled the latest in the sew_devel_2-0 branch and got the
>>>>>>>> following compiler error under Mac 10.8.
>>>>>>>> /usr/local/src/pgrouting_main/src/kdijkstra/src/k_targets_boost_wrapper.cpp:341:26:
>>>>>>>>        'vector<int>'
>>>>>>>> I can confirm that this does not occur on my Ubuntu machine.
>>>>>>> Hi Alec,
>>>>>>> I'm not very good with C++, but as a guess, can you edit that line 341
>>>>>>> and change it from:
>>>>>>> to:
>>>>>>> And let me know if that fixes your compile problem.
>>>>>>> Thanks,
>>>>>>>    -Steve
>>>>>>> _______________________________________________
>>>>>>> pgrouting-dev mailing list
>>>>>>> pgrouting-dev at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
