[pgrouting-dev] shortest_path using nodes instead of ways
Stephen Woodbridge woodbri at swoodbridge.com
Sun Oct 27 16:02:19 PDT 2013
On 10/27/2013 6:03 PM, cathal coffey wrote:
> Hi,
> I want to compute the shortest path between two points
> origin=(34.052299,-118.1812657) and destination: (34.141132,-117.853179).
> Here is what I tried to do.
> *Step 1:* Find the nearest nodes.
> _origin: the following returns 590279764_
> _
> _
> SELECT id
> FROM nodes
> ORDER BY st_distance(the_geom, st_setsrid(st_makepoint(-118.1812657,
> 34.052299), 4326))
> LIMIT 1
> _destination: the following returns 123007528_
> SELECT id
> FROM nodes
> ORDER BY st_distance(the_geom, st_setsrid(st_makepoint(-117.853179,
> 34.141132), 4326))
> LIMIT 1
> *Step 2:* Compute shortest path between origin and destination.
> SELECT *
> FROM pgr_dijkstra(
> 'SELECT gid as id, source, target, length AS cost FROM ways',
> 590279764, 123007528, false, false
> However when I execute this I get the following error.
> ERROR:  Start vertex was not found.
> ********** Error **********
> SQL state: XX000
> Why is this happening?
Just because you have a node in the vertex table, does not mean that you
will have it assigned a source ot target field in the edge table.
This is a new function that you can try out. It locates the nearest edge
then returns the nearest source or target node id along that edge.
create or replace function pgr_pointtoedgenode(edges text, pnt geometry,
tol float8)
     returns integer as
$body$
  *  pgr_pointtoedgenode(edges text, pnt geometry, tol float8)
  *  Given and table of edges with a spatial index on the_geom
  *  and a point geometry search for the closest edge within tol
distance to the edges
  *  then compute the projection of the point onto the line segment and
select source or target
  *  based on whether the projected point is closer to the respective
end and return source or target.
  *  If no edge is within tol distance then return -1
declare
     rr record;
     pct float;
begin
     -- find the closest edge within tol distance
     execute 'select * from ' || pgr_quote_ident(edges) ||
             ' where st_dwithin(''' || pnt::text ||
             '''::geometry, the_geom, ' || tol || ') order by
st_distance(''' || pnt::text ||
             '''::geometry, the_geom) asc limit 1' into rr;
     if rr.the_geom is not null then
         -- deal with MULTILINESTRINGS
         if geometrytype(rr.the_geom)='MULTILINESTRING' THEN
             rr.the_geom := GeometryN(rr.the_geom, 1);
         end if;
         -- project the point onto the linestring
         pct := st_line_locate_point(rr.the_geom, pnt);
         -- return the node we are closer to
         if pct < 0.5 then
             return rr.source;
         else
             return rr.target;
         end if;
     else
         -- return a failure to find an edge within tol distance
         return -1;
     end if;
end;
$body$
   language plpgsql volatile
   cost 5;
Use it like:
select * from pgr_pointtoedgenode('ways',
     st_setsrid(st_makepoint(-117.853179, 34.141132), 4326)),
     0.0013);
This is a new function that will be added to pgRouting 2.1 in our next
major release.
-Steve
More information about the pgrouting-dev mailing list
