[pgrouting-dev] Optimal Meeting Point (OMP)
dave.potts at pinan.co.uk dave.potts at pinan.co.uk
Thu Dec 18 07:34:09 PST 2014
Hi all
I can see a use for the  Optimal Meeting Point  code as well
is there a copy of the code available or item about the algorithm selected?
Dave.
> Hi Louis,
> If the CMake issue is the only remaining issue, could you just create a
> ticket in the pgRouting issue tracker, that we don't forget about OMP?
> And maybe you can use the issue tracker of your fork to list all remaining
> issues before being able to merge OMP into pgRouting. This could be for
> example finishing the documentation and tests.
> I think it's an interesting contribution, so if possible I would like to
> have OMP part of pgRouting.
> Best regards,
> Daniel
> On Thu, Dec 18, 2014 at 6:23 PM, Luís de Sousa
> <luis.a.de.sousa at gmail.com>
> wrote:
>> Dear all,
>> After various unsuccessful attempts to fix CMake I am running out of
>> time to pursue this little project. By some reason the Postgres types
>> are not being included in the OMP source folder and the compilation
>> fails, even if directly including the Postgres dirs.
>> I am shelving OMP for the moment. If anyone wishes to give it a try
>> please use this repo and brach:
>> https://github.com/ldesousa/pgrouting/tree/develop-omp
>> Time permitting I will return to this in the second half of 2015.
>> Regards and merry Christmas,
>> Luís
>> On 29 October 2014 at 17:14, Luís de Sousa <luis.a.de.sousa at gmail.com>
>> wrote:
>> > Hi Stephen, thank you for your reply.
>> > I was missing the references to the new module in the main CMakeLists
>> > file (at the root). I copied the instructions from the Johnson
>> > algorithm as you suggested. Now I have an error message from CMake:
>> > CMake Error at CMakeLists.txt:263 (add_library):
>> >   Objects of target "omp" referenced but no such target exists.
>> > There must be something else missing, but in the new omp folder
>> > structure there seem to be all the required CMakeLists files. I
>> > probably need to learn the basics on CMake; in the meanwhile, any
>> > other suggestions are welcome.
>> > Thank you,
>> > Luís
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.info
More information about the pgrouting-dev mailing list
