[pgrouting-dev] Proposing a wrapper: Point to Point Dijkstra Routing
Daniel Kastl daniel at georepublic.de
Mon Feb 3 22:49:22 PST 2014
On Tue, Feb 4, 2014 at 3:17 PM, smita dolly <smit402 at gmail.com> wrote:
> Hello,
> I would like to contribute to pgrouting-contrib repo by committing a pgsql
> script which basically intends point to point routing using Dijkstra as the
> back-end algorithm.
> This script has been tested on the following versions:
> 1.       PostgreSQL - version 9.1
> 2.       PostGIS - version 1.5
> 3.       Pgrouting - version 1.05
> Can I please know the procedure to go for the same?
> Thanks and Regards,
Thank you very much for your offer!
The "pgrouting-contrib" repository didn't work well unfortunately (or we
didn't do it right), so we are trying a different approach now as described
on this Wiki page:
https://github.com/pgRouting/pgrouting/wiki/Writing-functions
So you publish your code as Github "Gist" and add a link (and short
description) to the Wiki page. Let me know if you're not able to edit the
Wiki.
It would be great, if your point to point routing would also be available
for pgRouting 2.0. Are you planning to work on this?
Regards,
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140204/0e0107ad/attachment.html>
More information about the pgrouting-dev mailing list
